alternator/battery charging circuit
mark_i
Post Thu Feb 15, 2007 10:16 am
Help needed with this one...
Battery totally dead, started OK with a jump start from another battery, but alternator failed to charge the battery after 1 hour of driving.
Replaced battery and here is the problem.
With the ignition off and key out of lock, the Battery charge indicator is permanently ON (red)
When turn the key to On position, the Battery charge indicator goes OFF.
Engine starts and alternator voltage across battery terminals is 12.6V
What component would cause this "reverse logic"?
monkey
Post Thu Feb 15, 2007 11:05 am
poss alternator fault / engine earth cable may be damaged or need removing cleaning up and refitting to make good earth you could check this by conecting a jump lead from the engine block to the negitive battery terminal if that don't work it will be the alternator . the voltage charge should be 13.7 to 14.2 volts
Post Thu Feb 15, 2007 10:12 pm
Short circuit diodes in the alternator.
mark_i
Post Sun Feb 18, 2007 7:17 pm
Thanks Brianmoooore, Any chance to repair, replace or unshort the diodes?
Tried to remove the alternator, but the Blue cable tag is stuck onto the front 10mm nut and the rear nut and tag just rotate together.
The car will start, but runs as rough as. Apart from failing to charge the battery, any risk of other electrical damage ?
Post Sun Feb 18, 2007 9:25 pm
It's possible to change the diodes if you can get new ones and have a heavy enough soldering iron, but it will be a lot easier to get a replacement from a scrapper. If you are going to remove one yourself from a scrapper, unscrew the little regulator pack on the back of the unit first, and check there is a decent length of carbon brush left.
You won't do any harm to your car by running with an alternator that isn't charging, but it won't run for long.
The engine ECU has probably lost it's memory of the idle settings, due to the dead battery. It will sort itself out within 50 miles or so after everything is repaired.
Disconnect the red wire from the old alternator and tape up the end well before you attempt to drive the car.
Get a pair of pipe grips or similar on the cable tags to hold them while you unscrew the nuts. Alternatively screw them up and shear them off, so that you can get at the rear nuts.
mark_i
Post Wed Feb 21, 2007 12:07 am
Thanks again Brianmoooore, alternator from scrappers has fixed the charge indicator light, it even had a longer set of brushes so that was a bonus.
Some moooore questions though.
Now the handbrake indicator also shows a reverse logic: on with ignition on, but goes out with handbrake on and the engine started. Looks like there is a diode on the instrument cluster that is connected between the charge and handbrake lights. Replace diode?
The replacement alternator output never reaches the 14v output, 13.8V max, never goes beyond. Problem?
The studs for the two Bosch alternator terminals appear to be poorly attached. After removing the top nut and tag, the lower nuts and studs appear to rotate together without doing anything. I want to remove them to replace the correct black plastic terminal shroud. For the M42, the shroud open end is angled to point backwards towards the wiring loom box that is bolted underneath the inlet manifold.
The ECU has not recovered after 2 hours. Engine hesistates under load, feels like when the sparkplugs need replacing or the injectors aren't squirting. This is an M42 4-pot that ran perfectly before my UK trip and the dead battery/alternator problem. Engine idles OK, but struggles once the throttle is opened approx. 1/3.
Post Wed Feb 21, 2007 12:26 am
Handbrake indicator is just connected between fuse 10 (12V ignition) and the simple switch on the lever, AFAIK.
Look under the handbrake boot, and I expect the ferule on the end of the wire has come adrift, and is shorting when the handbrake is on.
13.8 volts O/P sounds OK.
When the nuts that holds the wires on an alternator are unscrewed, if the tags turn with the top nuts a little, it will slacken the inner nuts a little. The inner end of the stud usually sits captive in a socket, and once the inner nut is tight, everything else should be tight. Don't over tighten, as there are plastic parts involved.
For the running problem, check you haven't torn a perished main air hose or caused some other air leak, when changing the alternator.
mark_i
Post Sat Feb 24, 2007 10:29 am
Thanks again... the handbrake on wire was not held in the switch, got disturbed when I cahnged the rear ashtray bulb. Seems that is normal for the handbrake light to illuminate when switching on the ignition irrespective of whether the handbrake applied or not.
The running problem is similar to the symptoms described in the juddering/kangaroo thread currently being discussed. No air leak, so I'll check out the FPR and vacuum tube to throttle body plus the other suggestions.
