megasquirt and cosworth?
fuzzy
He who sleeps with "Gingers"
Post Sun Feb 18, 2007 3:39 pm
i know nothing about megasquirt but im wondering if it would be beneficial (powerwise,not concerned with economy) to use this system over the tried and tested stage chip in a level 6 cosworth ecu.would i be able to get to my goal of around 370-380 bhp easier with this? using the nessesary larger flowing injectors of course. cosworth tuners tend to dismiss anything that strays from the tried and tested path of tuning. :wink:
stuartgallafant
Post Sun Feb 18, 2007 3:45 pm
the only other brand i've ever heard of cossie boys using is emerald and motec. i suppose you could have a go with MS and then you'll be a pioneer in the game!!!
m-dtech
Unapproved Trader caution
Post Sun Feb 18, 2007 4:01 pm
quite a few of the ford boys using MS mate.
there is a dude on ebay usualy selling MS kits for cosworths.
i mind you had bother with fueling, MS lets you control squirt and spark :)
Turbo-Brown
Boost Junkie
Post Sun Feb 18, 2007 5:02 pm
I've wondered on and off (and seen other people have wondered the same thing) how, when every engine is different in some way or another, a generic chip can do a proper job of controlling an engine.
I'd say go for it with the MS Fuzzy. The cossie's not got anything special to control, it's just a good ol' bread'n'butter engine :D
Ant
Retired Team Member
Retired Team Member
Post Sun Feb 18, 2007 5:44 pm
No reason why MS would not work fine on the YB, if you used dual tables for fual and spark you could add in boost control and be able to hot swop maps on the fly
the latest firmware allows you to set what boost you'll see based on throttle position, and gear selection , no tried those yet, Beta testing still in progress.
Turbo-Brown
Boost Junkie
Post Sun Feb 18, 2007 6:39 pm
That'd certainly be handy if you set it up so that you had a rain map and a dry one. Sure we've all been caught out by a sudden wodge of boost when the roads are damp :o
Kos
Post Sun Feb 18, 2007 6:46 pm
stuartgallafant wrote:the only other brand i've ever heard of cossie boys using is emerald and motec. i suppose you could have a go with MS and then you'll be a pioneer in the game!!!
stu , there is a reason they use real management systems such ar DTA and emerals, the top end mo-tec systems are in a different league together with autronic
motec i belive is the only stand alone ecu capeble off runing a "vanos" type engine
the cossy mangement system is very mappable as it is, dips346 cossy runs on standard system and pushes 400bhp on it , your engine spec aint far off 400 either
