Hey zone, Have a bit of a tyre issue and got told to get the beads re sealed with bead sealer, Is it easy to do yourself ? or do you need to take the wheel to a tyre specialised to get this done ? how is this procedure done if you do it yourself ?
tyre beads re sealed
stuartgallafant
Some of you lot are wimps! I've sat beside the road in a far away land and fitted a tube to a tyre armed with only a couple of screwdrivers!.stuartgallafant wrote:you need a tyre fitting machine to do
Easier to take it to a tyre fitters, though!
stuartgallafant
