i hate my e30 2day!!!
tbg
Post Sat Feb 17, 2007 5:03 pm
how do i change the drivers door lock barrel?
been trying to do it for 2 hours and haynes manuals are dogshit, i dont know why people think they are so good, they hardly go into any detail.
you cant even see....let alone get to the lock barrel, or feel it!!! even after taking the door to pieces, i ve stripped it bare and i cant believe bmw would be happy with this design. any help would be much apperciated. tommy
eko
Old timer
Post Sat Feb 17, 2007 5:07 pm
There is a `horseshoe` shaped clip that holds it in place!
I use a long flat head screwdriver,lever against the door frame a flick it off :)
Admitidly it is a fiddly job :mad:
tbg
Post Sat Feb 17, 2007 5:13 pm
thanks ill see how i get on....... think ill do it 2mozorrow moring now tho as the light is fading
dazleeds
old skool raver
old skool raver
Post Sat Feb 17, 2007 5:23 pm
:roll: need to do mine tmoro too :cry:
www.oldskoolfantasy.co.uk
eko
Old timer
Post Sat Feb 17, 2007 5:25 pm
10 minute job once the door panel is off!
Honestly use a mega long screwdriver and its a doddle to do winkeye
dazleeds
old skool raver
old skool raver
Post Sat Feb 17, 2007 5:27 pm
eko wrote:10 minute job once the door panel is off!
been there many times
but i still hate em lol
cant get my arms in there no wayyyyyyyyyy :roll:
eko
Old timer
Post Sat Feb 17, 2007 5:29 pm
Yeah,probably helps if your a skinny fecker like me :)
Worse part is getting the clip back on,sore finger time!
dazleeds
old skool raver
old skool raver
Post Sat Feb 17, 2007 5:31 pm
dnt remind me :cry:
i'll have ripped up arms tmoro :roll:
ric325i
Post Sat Feb 17, 2007 6:03 pm
yeah done that one.......its just one of those painful jobs you wish you didnt have to do.
getting it off aint too bad but putting it :cursin: on takes some major patience!
Demlotcrew
Post Sat Feb 17, 2007 7:55 pm
I take the window mechanism out only a few nuts and bolts.
Andrew
Chris-W
Post Sat Feb 17, 2007 7:57 pm
It's the 4drs and tourings that I hate....
Post Sat Feb 17, 2007 8:13 pm
Lower window guide swings out of the way after removing just one bolt.
316eyes
Post Sat Feb 17, 2007 8:20 pm
Brianmoooore wrote:Lower window guide swings out of the way after removing just one bolt.
Not up to your usual standard, Brian. :D
Which bolt? :?
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
Post Sat Feb 17, 2007 8:28 pm
The single bolt that holds it! Not much of a choice.
Pull the metal part of the guide down slightly and it will unhook from the top part. Then swing the bottom across and tuck it up into the winder mech.
SPADGE
Which bolt? :?
At a guess i would suggest the lower one on the window guide :D
tbg
Post Sun Feb 18, 2007 4:06 pm
ahh lovely all done, lock replaced. needed to be done after some fecker tried to break into my car with a screw driver. also had a go at the boot with a crow bar i guess so i had to replace that aswel! all gud now tho. thanks ecko for the horseshoe explaination really helped me!. tommy
eko
Old timer
Post Sun Feb 18, 2007 6:35 pm
tbg wrote:ahh lovely all done, lock replaced. needed to be done after some fecker tried to break into my car with a screw driver. also had a go at the boot with a crow bar i guess so i had to replace that aswel! all gud now tho. thanks ecko for the horseshoe explaination really helped me!. tommy
No problem mate,glad you sorted it :)
