what is this sound? (soundclip) rattle/tap
liam012
Post Sun Jan 28, 2007 9:06 pm
Update - as i have been diagnoing this i updated title so it makes sense with where i am a now - basicly 2 problems:
1)something is rubbing against the lower timing cover...(whirring metal noise)
2)tapping rattle most evident from last few seconds of 28 second sound clip below - i have replaced the oil spray bar/water pump/viscous/alternator and disconnected power steering,
the ratling/tapping is very deceiving, all i can ascertain is front of block, i cant decide up in cylinder head or down in block
either way it dont look good:
soundclip link here
if you listen to this and it rings a bell please let me know i would be really grateful
thanks
old thread original complaint:
been trying to source the sound coming from the very front o t the engine- thought maybe it was the pulleys or alternator as it sounds like a metal wheel going around inside a metal sleve with no beaing or lubricant - however decided to test the viscous with the newspaper and it stops very very easy?
could this be the cause of that rotten sound?
editied title....
edit 2 add sound
mrLEE30
Post Mon Jan 29, 2007 7:54 am
a locked viscous will mean a very noisy fan type sound sort of a constant woosh, if yours stops easy then it is not locked!!
your sound could be water pump, alternator, power steering ect etc
mrlee
Post Mon Jan 29, 2007 8:49 am
Fan should stop easily if it's not being called on to cool the engine!
Take the belts off and run the engine for half a minute or so without them.
Next, I would start worrying about the cam belt idler!
liam012
Post Mon Jan 29, 2007 10:00 am
i have never heard my viscous whoosh
i drove 20 miles got out of the car immediately placed paper in fasn stop easy.
what is the cam belt idler? it doesnt sound friendly.....
liam012
Post Mon Jan 29, 2007 11:55 am
i have just had an awful thought - perhaps that awful sound is the timing belt rubbing of the cover 8O
please god no - that would mean a ridiculous ammount of work would it?
strange as belt and tensioner are new.
any quick test i can do to make sure its allright to drive the 20 miles home?
try and twist the belt 90 degrees or something and if you can its too loose - that sort of a thing....
mrLEE30
Post Mon Jan 29, 2007 2:25 pm
as brian says run with no fan belts on, if it stops it is probably your alternator/power steering pump. alternator bearings are easy to change, power steering pump is not but i doubt it is this.
if the noise persists without the fan belts on then it could be the cam belt/ tensioner / waterpump in which case i would avoid driving the car until you know what the noise is. to inspect would require removing the cam belt cover at a minimum, and more likely the rad and cam belt it self. I assume when you changed the belt you also changed the water pump?? silly if you didn't
remove the belts and let us know what is the sound situation
mrlee
kam-325i
Post Mon Jan 29, 2007 4:05 pm
liam012 wrote:as it sounds like a metal wheel going around inside a metal sleve with no beaing or lubricant
Water pump......
Bearing worn causing impeller/pump thingy to gring against casing.....?
liam012
Post Mon Jan 29, 2007 6:07 pm
i think you are right kam - cause sometimes it makes a tapping sound which could easily be the impeller whacking on something?
though just direct sprayed the alternator and the noise sort of stopped for a second but the tapping started then went then started
Post Mon Jan 29, 2007 6:58 pm
If this is an M20 engine, there's a rubber cover blocking a hole at the back of the timing belt covers, just above the alternator and below the cylinder head join. Remove this and you can get an idea of the belt tension, and whether or not it's disintegrating against the front cover.
gareth
Post Mon Jan 29, 2007 7:20 pm
are you losing any coolant though the 'nose' of the water pump? this is an obvious sign of the bearings giving out and the seals failing as a result (or more the seals failing and killing the bearings by filling them with coolant) every BMW engine i've had so far has needed a new one at some point so i guess these are a weak point?
not expensive to replace though, about £30 or less from GSF iirc and an afternoon will cover swapping it. if you do, pull the rad out and grilles off as it makes life a lot easier. then curse BMW for putting the bonnet hinges at the front!
gives you a chance to change the coolant too which is never a bad thing
liam012
Post Mon Jan 29, 2007 9:27 pm
haaaang ooooon a second
this would explain my weird problem of coolant not bleeding up right
especialy in the top long hose i always have to give em a squeeze to get them to heat up even after bleeding properly
fr instance driving home from the garage today i stopped twice to check as i was a bit nervous and had to give the hose a squeeze to get it to warm up...
maybe there is low water pressure
strill what good the impeller be hitting to give the tapping noise - i under stand a colapsed bearing would give the metal whining noise but the intermittent tapping....
bloody q and h pump... gonna get me a febi.......
will wip of the alternator belt though as the sound is desperatley close to there.
kam-325i
Post Mon Jan 29, 2007 9:50 pm
When you take of the alternator belt, this "disconets" the drive to the water pump as well. without the engine running, give the fan a spin, you will feel any play in the water pump bearing by seeing lateral movement in the fan.
liam012
Post Mon Jan 29, 2007 9:55 pm
thanks - i forgot about that....
will let ye know how it pans out....
gareth
Post Mon Jan 29, 2007 10:02 pm
there will also be a small amount of play in the fan clutch. better would be to pull of the fan to check the pump. the belts should be left on to hold the pump while you undo the fan. i think it's a left hand thread too... can't quite remember but worth bearing in mind!
kam-325i
Post Mon Jan 29, 2007 10:04 pm
it is a left hand thread.
liam012
Post Sun Feb 04, 2007 8:34 pm
i just installed a febi pump today it had plastic impellor?
the no name pump i took out had a metal impellor.
and to add insult to injury the horrible noise is still there....
damn
bled up the system (properly) and not only stone cold bottom hose /rad/ and rad bottom hose but other two hose get hot quite quick.
ripped thermostat and gave it the kettle test
only opens about 6 mm.
now my car is beacehed - which is annoying as i was feeling pretty cocky after finishing up changing the water pump in about 2 hours.
i guess next port of call is a new thermostat and try to bleed up again
i wish i was a drinker, coz i would be drinking now.
liam012
Post Sat Feb 17, 2007 11:12 am
pump changed
alyternator changed
visocus changed
metal on metal sort of sound still there best decribed as trying to sand a giant saucepan with small glass bottle (hope that makes sense)
and the tapping / rattling is still there and upsetting me....
Post Sat Feb 17, 2007 11:16 am
defo sure it's coming from the engine and not the usual noisy gearbox chatter at idle, doesn't go if you depress the clutch does it?
liam012
Post Sat Feb 17, 2007 4:13 pm
clicky for the sound
doesnt it just sound awful?
at 24 seconds you really hear the horrible metal sound - and it really is most audible from just above the camsprocket housing. (sorry mean cam pulley by distributer - sounds like it is coming from in therre- thing is i had it all off when doing waterpump and there is no sign of wear on the belt or belt housing -
out of my depth now, no ideas, replaced what i thought to be the culprit....
as more the tapping/rattling
one thing at a time...
Post Sat Feb 17, 2007 6:10 pm
Just pure silence on my PC! Am I missing some software or something?
liam012
Post Sat Feb 17, 2007 6:18 pm
you must have volume down brian? either in taskbar down on your right corner (sometimes the mute button is ticked which disables sound even thoughtthe volme is up) orin windows media player - it is only an mp3 so nothing special.
i have spent the last 2 huors at it and i havre established that the horrible metal whirring noise indeed the lower timing cover - what boils my bacon is that i had this off last weekend and noticed nothing - i do notice that where the top and the lower metal timing belt covers meet just along side the alternator if i press the bottom cover hard enough i can about 90% eliminate the noise.
what could that be?
and the ticking/tapping is just not at all making sense here there and everywhere.
not sure exactly what the next sensible thing to do is? (bar turn off the car before the belt snaps if it is danger that is...)
bigun
Post Sat Feb 17, 2007 6:19 pm
sounds like its tappets getting no oil have a look at the spray bar see if its blocked
liam012
Post Sat Feb 17, 2007 6:32 pm
installed new one 2 weeks ago - looks allright
liam012
Post Sun Feb 18, 2007 12:16 pm
ok i really have checked the spray bar area and the rattling/tapping is not coming from there - infact i dont think it is "in" that area at all,
any other possibilities besides strvation on tappets?
Post Sun Feb 18, 2007 4:44 pm
Why can't I hear anything!!
I get downloading from site, then "done", and all I get is a completely blank, white page.
hairydave
Post Sun Feb 18, 2007 4:49 pm
Brian, try right click save link as... Save it to desktop, then double click on it. This should then play the sound.
Post Sun Feb 18, 2007 5:24 pm
hairydave wrote:Brian, try right click save link as... Save it to desktop, then double click on it. This should then play the sound.
Thanks, that worked! And I get pretty psychedelic patterns all over the screen!
I can hear the noise now, but I don't know what it is I'm afraid.
Get a 3 foot length of garden hose, stick one end in your ear and move the other end around the engine.
Best suggestion I can think of is that the centre stem of the cam belt tensioner has come loose on it's bracket (not unusual) and is moving around. This usually throws the cam belt forwards into the cover though.
sam325is
Post Sun Feb 18, 2007 5:53 pm
right click link, save target as, then open it with a media player, you have got something disabled that not letting links be opened with WMP or whatever player you use
liam012
Post Mon Feb 19, 2007 11:49 am
Brianmoooore wrote: Best suggestion I can think of is that the centre stem of the cam belt tensioner has come loose on it's bracket (not unusual) and is moving around. This usually throws the cam belt forwards into the cover though.
brian
could this cause the tapping/rattling too? as well as the whirring metal sound?
kam325itouring
Post Mon Feb 19, 2007 12:13 pm
it loads up on windows media on mine brian....
Post Mon Feb 19, 2007 2:13 pm
liam012 wrote:could this cause the tapping/rattling too? as well as the whirring metal sound?
Don't know from here, but if that's where the sound is coming from.......
Oil pump drive is in the area as well, and the shaft that turns the pump has been known to fail. Can't see why it would make a noise like this though.
Post Mon Feb 19, 2007 2:14 pm
kam325itouring wrote:it loads up on windows media on mine brian....
Does on mine when I follow hairydave's instructions.
Morat
Post Mon Feb 19, 2007 5:43 pm
bryan, try right-clicking on the link and choosing "save link as" (firefox) or "Save Target As" (Internet Explorer Wrongness) and chucking it on your desktop. Open it from there using media player, winamp or whatever you use for music...
slinky2000
Location: Ireland - North(Portadown) and South (Limerick)
Post Mon Feb 19, 2007 11:12 pm
I thoguht mine was makign funny noises, thats terrible mate, best of luck with it :)
liam012
Post Sun Feb 25, 2007 8:08 pm
belt changed today
intermediate shaft pulley had come freakin loose?
belt was a tenth thinner 8O cambelt cover had a dent worn in it bhy the belt and pulley 8O
talk about lucky
fixed it all up now
but by some sort of sick joke my rotor arm mashed my distributer cap when i tried to fire it up first time
needless to say no spark....
i am still trying to figure out in my head how on earth i managed to put the cap and rotor on SO wrong that the rotor managed to snap and fully snap one of the dissy cap terminals...
i am trying to think if i could do it on purpose and i dont...
