bulbs
jcjdavis1
Post Fri Feb 16, 2007 7:21 pm
Hi I was replacing small bulbs above head/foglight switch,headlight adjuster but could not get them to go in.I bought lucas 1.2w capless.Are these the correct bulbs?The ones I took out had yellow plastic base.
Post Fri Feb 16, 2007 9:15 pm
All these little bulbs should be capless type. Never seen any with a yellow plastic base!
jcjdavis1
Post Fri Feb 16, 2007 9:35 pm
Hi I took them to the auto shop to show and they gave me the 1.2w,but I cannot get them to fit in the bulb holders.I am sorry now that I binned them.
jcjdavis1
Post Sun Feb 18, 2007 6:43 pm
Hi Brian found bulbs with yellow plastic base.Would they be Factory fitted?
sam325is
Post Sun Feb 18, 2007 6:54 pm
those bulbs look a bit big although it is hard to tell from a pic. the bulbs you need shouldnt have any base on them, they are all glass. they sit in little black holders and pull out, you then push the new ones in, if you have a loacl bmw dealership they will have them there
Gortour
Post Sun Feb 18, 2007 6:59 pm
The yellow bit is just a holder. Usually these bulbs just sit in the yellow holders and the single wire each side gives the connection. They are removable from the holder - usually. The bulbs are the same as the plain glass ones if you remove them from the holder.
jcjdavis1
Post Sun Feb 18, 2007 7:19 pm
Hi I wiil head to the dealers as I have broken three capless trying to get them to fit. Thanks
Post Sun Feb 18, 2007 8:56 pm
jcjdavis1 wrote:Hi Brian found bulbs with yellow plastic base.Would they be Factory fitted?
Never seen anything like that in any E30, and I've got a couple of very late tourings here!
jcjdavis1
Post Sun Feb 18, 2007 10:21 pm
Hi I binned the ones from my 89 tourer,these I had from my 90 316i.They were on the headlight adjusters control.
