What is the pin in the toolkit for?
pictonroad
Post Fri Feb 16, 2007 6:21 pm
Quick question, what's it for?
James
Post Fri Feb 16, 2007 6:23 pm
is it for removing the towing eye cover on mtec kits?
ajm-e30
Post Fri Feb 16, 2007 6:32 pm
if its the long rod with the plastic on the end u use when ur putting the wheel back on, insert it into the desired bolt hole and it wil hold the wheel up so u can put the wheel nuts in
pictonroad
Post Fri Feb 16, 2007 6:42 pm
ajm-e30 wrote:if its the long rod with the plastic on the end u use when ur putting the wheel back on, insert it into the desired bolt hole and it wil hold the wheel up so u can put the wheel nuts in
these Germans think of everything...
Is there a blow job machine at the back of the glovebox or is that only on the Sport model? winkeye
bmpaul
Post Fri Feb 16, 2007 7:13 pm
sorry too butt in but i've been scratching my head for 4 years on each of my bmw's about that little sod! cheers guys
E39 530d M-sport- quite nippy
ian332isport
Post Fri Feb 16, 2007 7:58 pm
It's also used as the thing to turn the spark plug socket. You put the rod through the hole and use it for leverage.
Ian.
harry_p
Post Fri Feb 16, 2007 7:59 pm
isnt it also the handle for the sparkplug wrenches too?
cheers,
harry
carlos_320i
Post Fri Feb 16, 2007 10:09 pm
Thanks guys I was wondering what the bar with the bit of plastic is for 8O
