as above the fuse for my economy,temp,fuel gage,rev counter, heater,etc keeps blowing as i have to replace it every day!
but i noticed today if i push the indicator stalk forward to put my beam on the fuse works and the rev counter starts working but the other dials struggled to move to the correct position ,then about 5mins after turning my beam off, a little bit of smoke started coming from the indicator stalk/steering wheel??
and also every now and then my dipped beam doesnt work and the light comes on on the check board above the rear view mirror??
economy/fuel/temp gage,rev counter fuse keeps blowing?
snoops
- Major Helmet
jcjdavis1
Hi I am no expert but I would be looking at a faulty wiper stalk ,live cable might be earthing somehow.
snoops
- Major Helmet
is it the wiper stalk then? as the problems a related with the indicator stalk as when i indicate left sometimes it starts flashing fast, the smoke was coming from the indicator stalk?
Your OP doesn't make much sense, as it refers to a fuse blowing, but you mention functions which aren't on the same fuse. What fuse number?
You then go on to suggest the fuse repairs itself by pushing the indicator stalk forwards???
snoops
- Major Helmet
yes that what i dont understand the fuse keeps blowing and so the heater,all the gauges apart from speedo stop working, when i replace the fuse they all start working but for some odd reason today when i put my beam on and the rev counter starts to work and the other dials move really slowly struggling to get to the correct position, then after i did this smoke started coming from the indicator stalk and behind the steering wheel which smelt of burning??
Brianmoooore wrote: What fuse number?
snoops
- Major Helmet
sorry i cant remember off hand and the cars not with me
mrLEE30
then he cannot help you!!!
have you changed or played with the stereo recently....fuse for supply is sonetimes shared with tacho etc
mrlee
mrlee
snoops
- Major Helmet
finally i solved this problem today, after removing my gear gaitor it appeared to be the reverse light cable getting damaged when changing gear causing a short and so the fuse was blowing, it was fuse number 10.
If you had told me it was fuse 10, then I would have told you exactly where the trouble was by return!
Fuse 10 has nothing to do with the heater, dipped beams or smoke from the steering column.
snoops
- Major Helmet
jcjdavis1
live cable might be earthing somehow.[/quote]
Hi I was partially right.I might be learning something at last.
