Fixing fuel gauge.. help needed please
Dr Firefly
E30 Zone Doctor
E30 Zone Doctor
Post Thu Feb 15, 2007 12:11 pm
Right, I have no idea what the problem is, so I need some help troubleshooting please.
The fuel guage just flickers all over and has no relation to the amount of fuel in the tank - it isn't like it flickers at about the right point, the needle just swings wildly from side to side - sometimes hitting opposite sides 5 times in a second. Seems slightly related to bumps in the road.
I've taken out the gauges and tightened the grounding nut on the back of the gauge, as I've heard that can cause it, but that didn't help
I've taken out the SI board and replaced the batteries, as the tachometer wasn't working. Though the SI board still doesn't work properly (the MPG gauge only works for a few days at a time when the battery has been disconnected, and the SI lights switch between yellow and red even when newly reset) I wasn't sure if the SI board had anything to do with the fuel gauge. The rev counter, temp etc all works fine though now
What do y'all reckon? The actual sensor in the tank, or the SI board?
Was thinking it might be worth changin the SI board, as I know it's a bit knackered, and then seeing if the fuel gauge is still wrong, and then changing the sensor. Alternatively it would be nice to know if the fuel gauge has nothing to do with the SI board, cos then I could just change the sensor and not waste money sorting out the SI board which doesn't really bother me that much.
Cheers, Ian
DaveD
E30Zone Wiki Specialist
Post Thu Feb 15, 2007 1:26 pm
Its the sender...
Post Thu Feb 15, 2007 10:01 pm
DaveD wrote:Its the sender...
Or senders. Some cars have two.
Second one, if it exists, will be under the round cover under the back seat cushion.
Dr Firefly
E30 Zone Doctor
E30 Zone Doctor
Post Fri Feb 16, 2007 2:00 am
Is there anyway to tell which one is the problem, if I have two? Will a late '88 320 have one or two? Thanks for the replies (on a very boring topic I'm afraid) so far!
And so am I right in assuming it'll have nothing to do with the SI board?
Post Fri Feb 16, 2007 9:17 am
Shouldn't be anything to do with the SI board, unless leakage from the batteries has travelled a long way.
If you have two senders, short out the connections to them one at a time. This will make the gauge read twice what it should, but you should be able to determine which is faulty.
