More fuel pump questions...
Alyman
Seems like a few folk are having fuel pump issues at the moment... wonder if anyone can help with mine?
My 318i had been acting up quite a bit recently, same symtoms as other people have mentioned:
Stalling after a minute on cold start up, loudish buzz from the rear of the car (tank pump I'm guessing).
There has also been a bit of a petrol smell inside the car while driving and in the engine bay recently, but so far I had been putting that down to a shoddily sealed pipe coming off the injection rail.
Yesterday it stalled and now it just won't start - turns over quite happily but nothing catches. Won't bump start either.
I can still hear the pump working as the engine cranks so it's getting power. Does that mean I can rule out the relay?
I've heard people mention that there are two pumps in the system, one in the tank and one outside it somewhere. Would both of these pumps be identical to the ones from my 325i convertible shed?
Only early E30s (up to and including the first facelift cars) had the two pump set up. Later ones only have an in tank pump.
First thing for you do do is find out which you have.
Most likely time for a pump to stall is when cranking, or when it's been running long enough to warm up.
Pull the fuel supply pipe off the engine (one from the filter) , put it into a container and jump the fuel pump relay socket 30 to 87 to check the fuel pump.
smithy318i
Don't put this off. There are two short pieces of 8X13 fuel pipe under the inlet manifold. This is probably the cause of the leak/smell.There has also been a bit of a petrol smell inside the car while driving and in the engine bay recently, but so far I had been putting that down to a shoddily sealed pipe coming off the injection rail.
Alyman
Brian: - Cheers, much appreciated, i'll give that a shot at the weekend (til then I'll just have to soldier on in the "company" car - ye olde pug 205 diesel
Smithy: Thats where I think the leak is - I noticed those pipes when I was changing the inlet manifold gaskets and thought they looked a bit ropey - really should've dealt with it then... thats a scary pic, I'm gonna do the job while the car is off the road.. maybe invest in a fire extinguisher too!
Alyman
Well, I went out today and did the following:
Swapped the white relay from the 325i onto the car - no difference
Swapped over the pumps (had to swap the frames - the 318i had the two pipe system, but the 325i just had one) - no difference
Shorted plugs 30 and 87 on the relay with a wire (with fuel line into a bottle) - nothing (key turned to second click)
Does that just leave the ECU/DME as culprit?
smithy318i
fuel pump fuse?
Alyman
Number 11 isn't it? Thats the one I checked anyway, no probs there......
If you've jumped 30 and 87 on the pump relay, fuse 11 is intact, and the pump isn't pumping, then either you have a dud pump, or there's a break somewhere in the electrics.
Alyman
I've just realised what i did. I jumped 30 and 87 on the white relay, not the orange one
Hopefully i've not destroyed my ECU....
I'll go down tomorrow and have another go!
toughguych
Thats odd, my 325 fuel relay is green...!
toughguych
And its got "++0407" number on the top of it.
Fuel pump relay is just an ordinary four terminal relay. Nothing special about it, and you won't have hurt the ECU.
Alyman
Righty
Went back down today and jumped the connections on the (correct) relay.
Mucho petrol so the pump is working fine.
Swapped the fuel pump relay with the one from the 325i and tried to start the car - same thing, turns over but won't catch.
What's my next step?
Does the fuel pump relay switch on when you crank the engine? (Checking for power at fuse 11 is the easiest way to tell)
Alyman
I've never actually used a multimeter before but I'm up for giving it a try!
I take it I have to remove the fuse and stick the probes in instead? Does it matter which way round (red/black)?
I'm assuming it'll have to be set to one of the "v" positions - any pointers on which one (v with a squiggly line/v with a solid line over a dotted line?)
Sorry for the schoolboy questions!
Templ8e30
It'll be the v with the solid line over the dotted line (volts DC).
Doesn't matter which way round you connect it, if it's the wrong way round you'll just get a - beofre the digits.
Best of luck,
Iain T
Best of luck,
Iain T
2007 Mazda 6 2.0 estate
I'm getting the impression electrics aren't your strong point!Alyman wrote:I've never actually used a multimeter before but I'm up for giving it a try!
Fuse shouldn't be taken out, black wire should be to clean metal on the engine or car body (bonnet catch bracket) and the red wire should be to the actual fuse wire in the fuse (which you can reach with a thin probe, if you have the right kind of fuse).
v/solid line and dotted line is correct, set to 0-15 volts, 0-30 volts or similar, unless your meter is auto ranging.
Alyman
You're not wrong there! I once had a nasty encounter with a live wire that ended with a shower of sparks and the wire melted onto my screwdriver - I've given electrics a wide berth ever since!Brianmoooore wrote:I'm getting the impression electrics aren't your strong point!
I did the test on the fuse today - with the multimeter set to the 20 marker, as soon as the engine cranked the reading shot up to 11 ish, so I take it that means the relay is getting power...
That confirms that the relay is puling in, and supplying power to the fuel pump.Alyman wrote:I did the test on the fuse today - with the multimeter set to the 20 marker, as soon as the engine cranked the reading shot up to 11 ish, so I take it that means the relay is getting power...
Also confirms the crank position sensor is working.
Alyman
hmmm so the plot thickens...
what should i be checking next do you think?
Reading through previous posts it seems like options may be:
1. injector jammed open and engine flooded.
2. no spark at plugs
Any easy ways to check these things?
Alyman
Just been reading up on the net as to how to check sparking at the leads - I'll give that a shot tomorrow, try to narrow things down!
The crank position sensor is working, so you probably have a spark as well, assuming 12V + is getting to the + terminal of the coil.
To check, pull off a spark plug lead, push it on to a spare spark plug and lay that plug on it's side on the rocker cover. Crank the engine over, and it should spark every second turn of the crank.
If you don't have a spare plug, then remove one from the engine.
Alyman
Okay, plugs are sparking fine! (just put a screwdriver into the end of one of the leads and let it spark against the rocker cover)
My basic knowledge of engines (spark + fuel + air = vroom vroom) therefore leads me to believe that there's only a couple of things left that could stop the engine running..
1. No air
2. Sparks not going off at the correct moment (ECU? Broken cambelt? Timing?)
Or am i missing anything?
1. No air
And if the gap was too large, and the coil flashed over internally to the neg. LT terminal, goodbye ECU!!Alyman wrote:Okay, plugs are sparking fine! (just put a screwdriver into the end of one of the leads and let it spark against the rocker cover)
Alyman
Well, I hope I don't pay for my laziness! The spark check guide I read said nothing about endangering the ECU.... I just figured it would be easier than removing a spark plug from the engine (I have none spare)....
ECU is fairly robust as it happens, but 50,000 volts fed back into it is definitely not recommended!
After you crank this engine, does the exhaust smell of petrol?
Take a plug out immediately after cranking. What colour is it? Is it wet?
Your spark + fuel + air = vroom, vroom is basically correct, although compression should be in there as well, and the spark timing needs to be somewhere near correct. Fuel timing doesn't matter that much at all.
Alyman
Alyman
I went down to Partco and picked up some new sparkplugs and put them in to see if it made a difference...
And she runs! Albeit with the same old problem - really wanted to stall if the accelerator was released.
I guess now I've got to track down what is causing the car to run rich, and what is causing the cold idle problem. Maybe a replacement ICV throttle body TPS switch thing and AFM would be a good start.
