dodgy seats
sam325is
Post Wed Feb 14, 2007 8:12 pm
my passenger seat has something broken in it. when you are sat in the passenger seat going round a left bend fast and sharp the back rest of the passenger seat will lean towards the drivers seat the go back down....its like something isnt holding it on one side ?!?
also how do the backs come of 2 door e30 seats. i know about the screws and then pushing the panel up but how do i get past the lifters?
Post Wed Feb 14, 2007 8:41 pm
Pull the handles off!
If you're lucky, then one of the two screws that hold the seat backs on has come loose, and that is all.
Unfortunately, if a loose seat back screw is ignored, it puts stress on the hinge area of the seat, and the thin metal cracks where it is welded around the thick walled tube that forms the hinge.
This is a def finite MOT failure, by the way, so will have to be sorted.
There are three ways of dealing with a cracked base:
1/ Find an identical seat base in good condition. Doesn't matter if it's ex. 2 door or 4 door.
2/ Find an uncracked seat base with worn out fabric, remove the fabric from both and fit your fabric on the new frame.
3/ Strip the fabric off your frame, weld it up, and refit fabric.
sam325is
Post Wed Feb 14, 2007 11:18 pm
1 bolt missing. replaced it and all was fine. on the other side of the same seat the L shaped thing is cracked. thing the best option might be to drill out the spot weld from the L shaped bit and weld a new bit on like you said. i fear looking at my drivers seat.
