The alarm facility on the OBC?
pictonroad
Post Wed Feb 14, 2007 9:51 am
What's the crack with these? Does it count as an immobiliser for your insurance?
I've purchased a disklok to be safe but I was just wondering whether to tell my insurance it has an electronic immobiliser as well?
And on the same point, are they any good or a pointless frippery?
Ta
James
Greeny
Post Wed Feb 14, 2007 10:11 am
When I insured my cabby I told them it had the original BMW alarm and immobilser but they said it needs to be a thatcham cat 2 immobiliser and that the original immobiliser wasn't good enough.
You also need a certificate from a qualified fitter for the immobiliser before they you will cover for theft. The funny thing is mine is fitted with a Tracker and that made my insurance no cheaper :?
Gone but not forgotten.
('92 325i Cabriolet)
danger_mouse
Post Wed Feb 14, 2007 4:21 pm
Well the imobiliser has well and truely imobilised my car today... so if it's not good enough, how the heck do I get round the bu993r!
I just want to bring her home! :cry:
Got a CAT1 one on the CRX, and never had this trouble with it! :x
E30_BO1
Post Wed Feb 14, 2007 4:23 pm
Just pull the OBC out.
danger_mouse
Post Wed Feb 14, 2007 4:31 pm
Was that to me?
Is there a plug/fuse/jumper thing I can jimmy so i can get her home and sort her out properly, or is it a rip the whole dammed thing out job?
Hand book says something about a "Magnetic Code key", but none came with the car. :?
Jon_Bmw
Dangerous when thinking
Post Wed Feb 14, 2007 5:13 pm
Are you talking about the OBC code, or a seperate imobiliser? If its the OBC, disconnect battery, reconnect and go home.
danger_mouse
Post Wed Feb 14, 2007 6:04 pm
New to the intimate workings of the E30's security.
Have to say I didn't try that, but the battery was flat as a flat thing, so must have been as good as disconected.
Could it be that simple? Why didn't the mechanic at the garage think of it, kn0b head!
Will that a try when I go to recsue her.
DM
Jon_Bmw
Post Wed Feb 14, 2007 6:10 pm
But re-reading your previous post, I am thinking that it might be a fitted imobiliser because you mention a magnetic key which is indicative of how a large majority of imobilisers work.
Jon_Bmw
Post Wed Feb 14, 2007 6:14 pm
Just read your other post, this has nothing to do with the OBC i'm sure, its either the factory fitted or aftermarket imobiliser giving you grief. :(
If its an imobiliser problem at all? :mad:
danger_mouse
Post Wed Feb 14, 2007 6:42 pm
Jon_Bmw wrote:Just read your other post, this has nothing to do with the OBC i'm sure, its either the factory fitted or aftermarket imobiliser giving you grief. :(
The "Magnetic Code Key" I mentioned is described in the original owners' handbook (with the red E30 on the front and kept in the original Metalic grey folder along with other dealer papers and all the old MOT cert's) and is used via the driver's door lock barrel...
...so I'm pretty certain its OE.
I have transponder (looks like a big watch battery) type imobiliser key on the honda, and the "Magnetic Code Key" isn't one of them.
peejay
Post Fri Feb 16, 2007 2:23 pm
Both the OBC and magnetic immobilisers will have to have been set by you in the first place neither operate on a passive basis.
So if you put in a code to the OBC use the same 4 digits to deactivate it.
The old magnetic jobbies apparently packed up very quickly from new and BMW stopped using them as a result, very rare to get one still working now although you still do see extra barrel on the door for them. There was also a red led under the rear number plate that would illuminate if alarm was activated. But as I said you would have to have set it in the first place.
Good luck
PJ.
Life begins at 40 ( to matter!)
orangecurry
Post Fri Feb 16, 2007 5:46 pm
have you got one of these in the drivers door? If not, you don't have the magnetic key immobiliser.
