I have a water leak that i need to trace
mikeyboy
Post Wed Feb 14, 2007 12:52 pm
Hello all, i have acquired a 325i in the lovely cirrus blue, bought as a non runner a few plugs later she runs like a dream. i have a problem though, there is a leak coming into the driver footwell from just behind the ecu i think, i need to inspect closely but thought someone may no where to look first. the car has a sunroof if that helps?
dazleeds
old skool raver
old skool raver
Post Wed Feb 14, 2007 12:55 pm
check the drain trunk in the engine bay
drivers side looks like a trunk hence the name
pull off the plastic bit and clear out the years of crap thats got in there
may not be that its first place to check
hth
Daz
www.oldskoolfantasy.co.uk
smithy318i
Probably leaking in from the bottom of the windscreen at the scuttle panel.
MarkP
Post Wed Feb 14, 2007 1:52 pm
Do a search in the Technical section as im sure there are a few different threads about water leaks, might be of use to you. :)
E30_Aza
Post Wed Feb 14, 2007 4:34 pm
scuttle, behind the bulk head, inner arch etc... just had this problem with mine on the passenger side :(
ag-1982
Post Wed Feb 14, 2007 9:24 pm
mine was in the scuttle panel right in the corner on the passenger side .
mikeyboy
Post Thu Feb 15, 2007 1:17 pm
cheers people for the info i will do a search in technical forum. how bad were the scuttle panel issues?
E30_BO1
Post Thu Feb 15, 2007 2:09 pm
very bad. might as well break the car and smash the windowscreen.
