Is my fuel pump Ill?
toughguych
Post Mon Feb 12, 2007 7:12 pm
I cant figure out if my fuel pump is at fault.
Bad starting only occurs when car is cold.
It will fire up perfectly.
It will run for a min then stop and be a real bugger to start again.
Some say it will almost definatly be the fuel pump playing up.
Only thing I cant workout is why does it go on to start ok when the engine is warm?
325i Touring 1989.
toughguych
Post Tue Feb 13, 2007 6:11 pm
Bump.. 8O
Templ8e30
Post Tue Feb 13, 2007 6:58 pm
Could well be the fuel pump relay, they're known for playing up.
Normally when the pump fails it seizes up requiring a sharp tap to get it going again.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
toughguych
Post Tue Feb 13, 2007 7:28 pm
Ya, getting pump and DME relays tomorrow.
Then we will see!
Got to sort it, the car is fine apart from that dredful bad start condition.
Thanks for the response Temple8.
Post Tue Feb 13, 2007 7:34 pm
Connect a small bulb or LED to the fuel pump supply (green/purple wire at the socket under the back seat cushion, RH side), position it so that you can see it while driving, and see what happens.
Identify exactly what the fault is before trying to cure it!
toughguych
Post Tue Feb 13, 2007 10:33 pm
Thanks Brian,
Driving is fine.
Its when the car is warming up that I have problems.
Cold start= turn key, car starts, runs for 10 sec to 1 min fine then stalls.
Bugger to start again.
Car warm, no problems.
What do I look for with the light if I can see it whilst driving when the car is warm?
This is not just an intermitant fault.
It is a continuing series of events every time the car is cold.
Its so hard trying to pin the problem on one thing but I am sure it is just one thing doing this.
But which Thing..
:mad:
Post Tue Feb 13, 2007 10:37 pm
Light should be on all the time the engine is turning, whether cranking or running.
toughguych
Post Wed Feb 14, 2007 10:45 am
Have bridged the pump at the relay connection and it works good.
Relays are £15.00 for the two.
Am sick of throwing money at my car so is there any way I can test the Fuel pump and DME themselves?
Maybe I should do a search here when I get home from work later today.
Cheers Bri..
Templ8e30
Post Wed Feb 14, 2007 4:33 pm
If bridging the connection cures your problem then the relay is knackered.
Cheers,
Iain T
toughguych
Post Wed Feb 14, 2007 4:55 pm
Hi Iain,
When I bridge the connections the fuel pump starts going with ignition off.
Are you sugesting I do this then start the car and see if it runs ok?
But if the relay is stuffed how come it is ok when warm?
Post Wed Feb 14, 2007 7:00 pm
toughguych wrote:Hi Iain,
Pump will run continuously when the relay is bridged in this way. You are feeding power straight from the battery, through a fuse, and to the pump.
Bridge the relay, start and drive the car as normal and see if it has any effect on the problem.
Don't forget to remove the link when you park up, or you'll have a very flat battery when you next drive the car.
toughguych
Post Wed Feb 14, 2007 7:11 pm
Thanks Guys
Will try tomorrow and let you know.
toughguych
Post Thu Feb 15, 2007 5:54 pm
Its not the pump or relay.
Bridged the relay and same problem.
Starts fine, runs for 10 secs then slowly dies.
Then a real Biatch to start again.
Can I test the DME relay in the same way? If so, which pins?
Need to cure this cold start issue.
Martinaston
Post Thu Feb 15, 2007 8:03 pm
First thing first, New air filter ?
If yes then try pulling fuse 11 to kill the fuel pump and then the engine when you park it at night. In the morning put the fuse back in and see how well it starts and warms up. If its ok it could be the injectors are sticking open and flooding it overnight.
If it still runs rough or stalls i'd have a look at the blue temp sensor and check the resistance or just change it for a good one to rule it out.
There is NO nucleus.
toughguych
Post Thu Feb 15, 2007 8:16 pm
Thanks Martin,
New angle,
K&N Pannel filter is clean.
Will try your idea tomorrow.
Its not the blue temp sensor, its been changed twice!
Post Thu Feb 15, 2007 8:57 pm
toughguych wrote:Its not the blue temp sensor, its been changed twice!
How about the notoriously unreliable plug and socket under the inlet manifold that the temp sensor signal passes through?
toughguych
Post Thu Feb 15, 2007 9:03 pm
Been there Brian,
Short of a full wire and pin overhaul it all looks good.
Post Thu Feb 15, 2007 9:04 pm
It's not necessarily the pins and their sockets that are the trouble. The rot gets into the wires inside the lower rubber boot.
toughguych
Post Fri Feb 16, 2007 6:40 pm
Ok, took out number 11 fuse and let the car starve of fuel to stall.
Tomorrow when I start her we will see if this is the problem. ( Injector Sticking Open )
But, Its an ongoing similar state of start, run, stall, bugger to start. I can predict it.
When I was sitting in my car gently caressing the throtal so as to keep her going from cold I noticed:
The temp gauge needle spring to life after two mins.
Then the car ran fine without stalling after this.
Is this normal behavior for the temp gauge needle or should it rise smoothly?
Martinaston
Post Fri Feb 16, 2007 6:59 pm
Sounds more like a bad connection somewhere, the temp sender wiring runs through the plug brian mentioned.
It might be worth pulling the rubber boots off and checking the plug again.
Post Fri Feb 16, 2007 7:40 pm
This is a perfect description of a car with no cold running enrichment. I.e. the ECU thinks the engine is hot when it's still cold.
Not the symptom of an open circuit blue sensor though, more what happens when it the signal wire shorts, or has a resistance of a few hundred ohms, to earth.
You haven't managed to get the blue and brown sensor plugs on the wrong way around, have you?
toughguych
Post Fri Feb 16, 2007 8:12 pm
Ah, no Brian I have checked and they are on the right way.
So what do you recommend I do?
Post Fri Feb 16, 2007 8:52 pm
Unhook the ECU connector and measure the resistance of pin 45 (brown/red) of the connector to earth. Do it stone cold and at working temperature if you can.
toughguych
Post Fri Feb 16, 2007 8:56 pm
Will do.
toughguych
Post Sat Feb 17, 2007 5:58 pm
Ok, tested the resistance after being parked up for 20 mins.
It read 390 and rising slowly by the second.
If I had of tested it when I parked up I guess it would have been around 200 but it shows its working.
In the moring I will test it cold.
Post Sat Feb 17, 2007 6:39 pm
That's about right for hot.
toughguych
Post Sun Feb 18, 2007 7:25 pm
Resistance cold = 03.7
Post Sun Feb 18, 2007 9:41 pm
Assuminmg that means 3.7 kilo ohms (3700 ohms), then that's a reasonable figure.
Clutching at straws a bit, but try connecting a voltmeter between pin 45 of the ECU connector (ECU disconnected) and earth, and link pins 30 and anything with 87 in it together of the main ECU relay socket.
This will power the injector feed and put a voltage on the other pins in the plug and socket under the inlet manifold. You are looking for current leaking across to the temp sensor pin, which could confuse the ECU.
TINSNIPS
Post Sun Feb 18, 2007 10:52 pm
I had the same problem with my 325i the e.c.u was not sending a signal to the idle control valve, it would start fine, then stall cow to start again once warm run spot on. we found a dry solder jiont inside the e.c.u, quick resolder and a silica pack left inside the e.c.u sorted.
toughguych
Post Mon Feb 19, 2007 5:27 pm
Will try and get my head around it sometime this week,
Thanks Guys.
I may refit a spare ecu and see how my car responds.
