John.
CLUTCH FLUID DISAPPEARING????
bigjprogs
Can anybody please help? I got a red warning light come up on the dash of my 316i tourer a few months ago,I checked the fluids and found that the small round clutch fluid resevoir was almost empty,I topped it up,light went out and all was fine for about 2 weeks when the same thing happened again,since then I regularly have to top up,(every other day now!),but there is no fluid under the car or on the ground? Any suggestions much appreciated!!
John.
John.
fuzzy
is your drivers side footwell carpet wet? when my master cylinder went the fluid ran down the pedals and onto the carpet,but i suppose you would have noticed that by now
bigjprogs
No sign of any dampness in the footwells?
fuzzy
i cant think where the fluid could be going if its not leaking under the car or running down inside the car
it can only leak from either master or slave cylinders,the reservoir or the bits of hose connecting them
oze30
Mine leaked from the plastic elbow from the resevoir to the master. Didnt realise anything till I took my carpets out.
Try removing the under dash panel and feeling up on top of the pedals for the master cylinder. My bet is that its the same as mine. My carpet wasnt wet, but now, its managed to come thru as black smudges on my carpet (Its up high, but I still know its there!)
bigjprogs
looks like I'd better start lifting some carpets-thank you fer your help--John.
If the clutch fluid is disappearing then either the master or slave clutch cylinder is leaking. Doesn't matter which, as they need to be replaced as a pair in any case.bigjprogs wrote:I got a red warning light come up on the dash of my 316i tourer
There's no monitoring device for the fluid level in the clutch cylinder on a RH drive E30. Whatever put your red warning light on, it wasn't the clutch fluid.
