Block to inlet breather pipe
adamS
Tue Feb 13, 2007 8:10 pm
During my unsucessful HG swap I came accross this pipe with a spring inside.
I'm curious what's its responsible for and how it works. Anyone know?
thanks :cool:
chu346
Tue Feb 13, 2007 8:16 pm
Crank case ventilation pipe, to let out all the gases that get built up.
adamS
Tue Feb 13, 2007 8:31 pm
The scavanger system? So the gases are them combusted?
cheers
gcorky
Boost Junkie
Tue Feb 13, 2007 8:50 pm
oil vapour /mist .did you renew o rings top and bottom?if not may cause idling/running issues?
525 sport
Tue Feb 13, 2007 10:35 pm
It's not only a vent pipe. It's the pipe through which all the oil pumped to the cam and rockers gets back to the sump as well.
