Couple of q's about electric fans
liam012
I have measured space infornt of radiatot an it seems to be a good 16" square with room to spare - why do people say that an 11 or 12 inch fan is the max to use?
Also i have heard diffeent opinions on what is better: a fan on the front that blows air from the outside through the radiator (which i favour) or a fan on the inside that sucks air through the radiator.
which is actually better if any?
stuartgallafant
not sure about the size question, possibly to do with it weighing less???
regarding the fan position/type, its better to have it on the rear, sucking the cold air through the radiator. this way, all the radiator is exposed to the air and then the air is sucked through it at force, aiding cooling.... however, i cant imagine there'll be too much in it
The only reason to put an electric fan on an E30 is if there isn't room for the mechanical one. In this case it's unlikely that there's room for a "sucker"either.
The largest electric fan that will fit is the aircon fan of an E34, which, I think, is 16", although I haven't measured.
stuartgallafant
They're pointless and are far less reliable than the OE viscous set up. Electric fans don't run on nothing!stuartgallafant wrote:you hate electric fan conversions, dont you mr moore!!
stuartgallafant
StuBeeDoo
"Pull" type (ie. fitted between the rad and engine) fans are more efficient.
Different diameter fans are used depending on engine size. IIRC, a 12 or 13 inch fan is the ideal size for engines of around 2.0 litres. A fan that's too small for the engine's requirements will be on for too long and may not cool the engine sufficiently. Conversely, a fan that's too big will cool the engine more than adequately, but will be an un-necessarily heavy load on the electrical system.
The thinking behind using a Ford RS Turbo fan on E30's - even though the Turbo is only 1.6 ltr - is that Turbo engines have an equivilence factor of 1.4. Therefore it can be suited to a naturally aspirated engine of up to (roughly) 2.2 ltr.
I've been using an RS Turbo fan for a couple of years with no problem at all. I'm not sure if I'd want to use it on a 325i (or bigger) though. If I was running one of the bigger engines and wanted an electric fan, I'd probably go for a 5 or 7 series aircon fan.
HTH
Stuart.
HTH
Stuart.
Electric fans run on electricity, which has to be produced by the alternator, using power from the engine - at a total efficiency of about 20%.
I have no statistics to back up my reliability theory, but the viscous fan has one component which can fail (I've only ever replaced two), whereas the electric fan has a motor, a thermoswitch, relays, fuses and connectors, all of which can and do fail.
Engine temp will rise and fall much more with an elec fan than it will with a viscous. It does on mine anyway.
I will be attempting to use a viscous with the next engine change, I just cant trust the electric fan.
ian332isport
Mine used to when it was wired as a single speed fan. It's much more stable now it's wired for two speed operation.DanThe wrote:Engine temp will rise and fall much more with an elec fan than it will with a viscous. It does on mine anyway
Ian.
liam012
looking at ebay the viscous units are not to expensive - but when they are posted they get ruined as they need to be stored upright? is that correct
t
t
StuBeeDoo
IIRC, as long as you stand it upright for 24hrs before you fit it it won't be a problem.liam012 wrote:looking at ebay the viscous units are not to expensive - but when they are posted they get ruined as they need to be stored upright? is that correct
t
Any one know different??
Keg_gt
Am i correct in saying though that a viscos fan has more problems cooling when the car is sat still as i only have problems getting hot when im sat still for too long or in heavy trafic
liam012
no, the viscous unit itself design wise has no problems at all -
yours however sounds as if it is broke as it should be locking up and turning with the engine when the engine gets hot (ie: you are sat still or crawling in heavy traffic.)
when you are driving past 20mph you dont really need electric or viscous fan as the forward momentum is 'usually' enough to cool the car on its own.
its when you stop moving or drive real slow that the rad needs a fan - at this stage the electric fan k9cks in via a thermometer or the special fluid in the viscous thickens due to the heat and locks up to cause the fan to spin full pelt.
now those viscous units - are they postable or what - wondering the same as esbee
editied for the comma! it actually changes the meaning....
charlE30
Do you not have a local GSF or ECP? they sell the Sachs viscous fan clutch unit for around £28 + VAT.
Charlie
Charlie
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
liam012
unfortunately i live in the country
nearest village-3.5miles
nearest small city - 25 miles
nearest dealers - 50 miles
nearest GSF - 120 miles
post is my only option at the moment.
charlE30
liam012 wrote: nearest dealers - 50 miles
thinking about it, I had one delivered, left it standing upright for a day before fitting, works perfectly
Charlie
BMW F31 335d xdrive
BMW F31 335d xdrive
stuartgallafant
do you have a wiring diagram or an explanation of how you did this ian?ian332isport wrote:Mine used to when it was wired as a single speed fan. It's much more stable now it's wired for two speed operation.DanThe wrote:Engine temp will rise and fall much more with an elec fan than it will with a viscous. It does on mine anyway
Ian.
ian332isport
I did a writeup in this thread a while back.stuartgallafant wrote:do you have a wiring diagram or an explanation of how you did this ian?
http://www.e30zone.net/modules.php?name ... hlight=f18
I can do wiring diagrams as well if it helps.
Ian.
Ian.
If I could get an S50 radiator to fit it would be a big improvement
stuartgallafant
ian332isport
Demlotcrew
I dont agree, electric fans are only on when stuck in traffic where as a brand new clutch type fan (ie viscous) is on all the time. Even when driving on the motorway at 60.Brianmoooore wrote:Electric fans run on electricity, which has to be produced by the alternator, using power from the engine - at a total efficiency of about 20%.
Why did the M3s come with electric fans only?
Andrew
surj
im sure 325 fuse boxs have optinal aux fan connections
When a viscous fan is unlocked it is little more than free wheeling and absorbs very little power. At sixty on a motorway the ram airflow through the fan probably exceeds the airflow from the fan which is produced by the engine turning at 3000 RPM through the viscous, so the fan is actually adding a little power to the engine.Demlotcrew wrote:I dont agree, electric fans are only on when stuck in traffic where as a brand new clutch type fan (ie viscous) is on all the time. Even when driving on the motorway at 60. Andrew
