Brakes
E30_BO1
Post Mon Feb 12, 2007 6:29 pm
Have driven a few E30's and the brakes on them are sh*t compared to those on an e36 car. What sort of upgrade can be done to the front brakes for £250 say.
Jimbob
Post Mon Feb 12, 2007 6:37 pm
Stainless brake lines, aftermarket discs and pads. Not enough for bigger discs I'm afraid.
E30_BO1
Post Mon Feb 12, 2007 6:39 pm
You sure as their some people on e36coupe doing 330 brake conversions for around £350
DRIFTBOY
Post Mon Feb 12, 2007 6:43 pm
I've heard a cheap and effective mod is to use machined VW Corrado discs (280mm) and standard calipers mounted on adaptor plates to move the caliper out.
Should be able to do this for under £250 but I've not tried it so can't say if it's any good or not! :?
Jimbob
Post Mon Feb 12, 2007 7:04 pm
Yea those Corrado sets aren't bad, I think Gareth is running them so might be able to shed some light on that.
The E36 lot have already got the basis of 5 studs, not 4 like us :D
DRIFTBOY
Post Mon Feb 12, 2007 7:10 pm
Gareth is running the WMS kit, wich is the Corrado discs but also with 4-piston calipers. He told me they are very, very good!
But that kit will be over £250.
ed325i
Post Mon Feb 12, 2007 7:26 pm
The www.300mm.de set up can be put together for under £250. But you must have 16" or bigger wheels.
BadDave
Post Mon Feb 12, 2007 10:50 pm
I'm running 302x28mm fronts with 4 pot Brembo's
Put it together myself for about £280
Only cos I got the calipers cheap tho(ripped the guys arm off)lol
Makes a big differance, and works well with the ABS
