m tech kit question
Chaos
was the m tech kit an option from new on e30's or only available for the sports? i know u could order front and rear spoilers but were they the m tech/ sport ones ?
Chaos
causing havoc and mayhem wherever i go
certainly was, if u had the money it went on
Chaos
i thought so.
makes an interesting point with regards to insurance.
basically we can stick lsd, sports seats bbs (or even alpinas) and mtech kit on a "normal" e30 and not have to declare it as modified.
Chaos
johnono
but if they check the reg number or the vin if u have a lick, then it could go pear shaped
dont forget that there are young lads like us working for the other side
Chaos
i dont think that mattersjohnono wrote:but if they check the reg number or the vin if u have a lick, then it could go pear shaped
if it was an option from new then u can add it without changing the manufacturers official specification
Chaos
johnono
sounds good then, aslong as the lick isnԚ´t because of spinning it out on a rounderbout with uԚ´re new lsd , uԚ´re ok then
