Does the 316i e30 come with a air mass/flow meter
Emm3
Post Sun Feb 11, 2007 10:56 pm
My e30 has a ramair induction kit fitted and i want to change this back to a standard air box. I'm certain this has been bought 2nd hand as its marked with a white pen '1990 316i e30' like bits you get from the scrapper. Now the induction kit has got an air mass/flow meter which has a plug coming out of it but on my car its left disconnected? had a look for any unconnected plug but couldn't find anything.
e30Alex
Post Sun Feb 11, 2007 11:13 pm
Yes it does.It will idle like a pig without it.Alex
Im a two car man. Shame my bike gets used more.Damn the MOT!
Emm3
Post Sun Feb 11, 2007 11:14 pm
where does the plug go?
Post Sun Feb 11, 2007 11:38 pm
Can't quite make out what's happening here, but without an AFM, idle is all it will do properly.
AFM is built into the top of the air filter assembly.
There is a spare connector hanging off the loom nearby, which is only used on emissions equipped cars.
Emm3
Post Mon Feb 12, 2007 7:58 am
This has just one connector coming out of it. To me it looks like the connector which will make the thing actually run. you can twist the connector off and it just pulls out of the air flow meter and its round in shape but where does the other end of the wire go? the car does idle unstable at the moment and i'm guessing its to do with the meter not being plugged in.
Post Mon Feb 12, 2007 8:50 am
Still lost, I'm afraid.
1/ Your car will start and idle almost normally with the AFM disconnected
2/ Without an AFM your car will be undriveable, unless major mods have been made to the management system.
Emm3
Post Mon Feb 12, 2007 12:15 pm
Everything in the engine bay is completly standard all connectors but the car drives fine i did 100 miles when i bought it on the way home??????
Post Mon Feb 12, 2007 7:54 pm
Time for some pics!
