Ive ddone a search but didnt find what i was lookin for.........
Has anyone got a link/pics or write up on how to "open" a bosch ecu....
Ive got the outer covers off, but how do open the "board sandwich" inside?? cheers benjy
ECU help.......pls
benjy
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
benjy
Come on boys an girls............I know Top Gears on but its shit this week!!!
CHRISP
- Boost Junkie
benjy
I did think that, but he's not online i at the mo
eko
- Old timer
Ben,just done a Google search and got this info from an Audi site!
Shouldnt be much difference?
To fit the eprom;
1) Place ECU on a non static surface. Ive changed three so far and never warn an anti-static wrist strap, but maybe because thats because Im a negative person, who knows, but if you are a highly charged person, wear one and earth yourself.
2) Use a T1.5 Star drive (available from Halfords, Argos etc) to undo the five bolts holding the cover on.
3) Open the cover to reveal a protective anti-static piece.
4) Remove this cover and just place it in the cover for now.
5) Next you need to remove the main clip that holds the top PCB in place. This is in the form of what looks like a comb and clips around the main connector. It needs to be unhooked in order to remove the top board. You will need to use some thin nosed pliers to pull the clip out from one side.
6) It is a little tight, but can be unhooked using the afore mention thin nosed pliers. Unhook the other side in the same way as the first and raise the clip. This prevents the board being slid backwards and forwards, it needs to be slid backwards to open it out to gain access to the Eprom you are going to change.
7) Next cut the white crimping tag that stands above the circuit board in the middle. Unfortunately this is the only way you can remove the top printed circuit board. Its a very tight fit and needs to be but off in order not to damage the board trying to crimp it.
With this remove you now need to unclip the two green clips the are in each corner. You can see them in the picture above. These are easy to unclip.
9) With these two unclipped simply slide the top board back so that you can see the connectors of the board.
10) Now fold open the top board as seen below. The top board contains one exchangable eprom, which is the one you will be changing. The lower board also has one exchangable eprom, this is the turbo map eprom. Just ignore that one. All the other chips are soldered in and cannot be removed.
11) This is the board we are interested in, its the top board containing the fuel/ignition map eprom. Note your eprom will look different to this, this is my eprom I fitted 2 years ago when I first encountered boost cuts. It has an original GT3 map just with 7400rpm limiter and no boost cuts. So dont worry, yours will more than likely have a sticker on it with another 10 digit bosch part number on it.
12) This is the eprom we are changing. Note the small half circle removed from one end of the eprom. You use this marking to line up for which end is which for putting the eprom in the correct way round.
13) Remove the Eprom with a flat object applying equal force each end to lift the eprom out at the same rate so not to bend any of the legs.
14) With the eprom removed you will see the base of the connector. Also note the piece removed from the connector to aid alignment.
15) Here you can see the PowerOnTheRoad eprom (GT3 Seb2) placed next to the base connector in the correct orientation with both markings matcing up.
16) Line up the legs of the connector into the holes and press gently down so that the eprom goes all the way down.
17) Once pushed in fold the top board back over again and slide the main connector pins back in like before.
18) Push the holding clip back over again to hold board in place and push green clips down again.
19) Put the ECU cover back on and replace the star drive bolts.
20) Finally with all screws done up you are ready to put the ECU back in again.
And thats it, simply replace the ECU back into your engine bay as you removed it except doing everything in reverse. Not forgetting to reconnect the battery. Now simply start your engine and drive!
To fit the eprom;
CHRISP
- Boost Junkie
eko
- Old timer
benjy
The ecu in that link is different to the ecu ive got here.......but ive done it now so all's almost cool.......
Eko PM mate
Eko PM mate
