Hello Has Anyone Fitted The SA30 Scorpion Alarm to There Car
If They Have How Did The Wiring Go For The Remote Central Locking?
Fitting Scorpion Alarm
Fairly ordinary alarm. Shouldn't be any problems fitting it.
Most, if not all, the connections you require are in and around the glovebox area.
Archie14f
In The Instructions you have five different types of wiring diagram c/locking systems to choose from.....
vehcles with neg c/locking
vehcles with pos c/locking
vehcles with vacuum c/locking
vehcles with single wire c/locking neg to unlock
vehcles with single wire c/locking neg to lock
which is E30
which is E30
E30 has a wire which you earth momentarily to lock, and another which you earth momentarily to unlock, so I would think, the first one.
Archie14f
What colour Wires would be or number on the c/locking cpu for Lock Command & unlock Command or were would it be best to wire it to Thanks..........
Yellow/blue is lock request and green/blue is unlock request. Pick them both up where they emerge from behind the LH speaker panel, along with the interior light wire.
Indicators are blue/red and blue/black and are at the plug in the rear left of the glovebox.
Earth is the stud with all the brown wires above the glovebox.
12V constant live is the top left of the accessories socket.
Ignition interrupt is a white two pin socket with two green wires, fitted with a plug with a loop of wire, above the glovebox.
Starter interrupt is a black single pole plug and socket each with a black/yellow wire also above the glovebox.
Fuel pump is a green/purple wire which comes out of the duct at the back of the glovebox and disappears behind the LH speaker panel.
Archie14f
Thank You Very Much Brian For all Your Trouble All The Best Mate Frank.
