ARB link question
buster
Hi all,
Im fitting e30 m3 struts to my car.Which front arb link should i use ?
For those who dont know ,on e30's the arb link mounts on the front wishbone but on m3's they have a long link which connects to the strut housing.
Is the m3 one better ?
cheers andy
cheers andy
M3 setup is better
Not so much better, just a greater roll stiffness for a given diameter of ARB.
buster
so use the m3 one then and not the standard one.I supose thats why the m3 one was fitted in the first place
The probable reason the design was changed for the M3 was to make it easier to make the ARB adjustable.
- Homo Hair
Use the M3 one
gareth
do you have any pics of the M3 ones?
i'm wondering about retrofitting ARB droplinks to the struts as the links on mine seem to last 6 months before the bushes die. if the roll stiffness is increased (make sense now you mention it!) then it can only be a good thing!
Chris-W
gareth
ooh! looks nice!
i may have a go at that then, it looks fairly straightforward to knock up a bracket.
Only up to the optimum level - and that can only be decided by track testing.gareth wrote:if the roll stiffness is increased (make sense now you mention it!) then it can only be a good thing!
I spent four days at Silverstone a few years ago, with a professional single seater race team, and learnt an awful lot about suspension and general car set up in those four days - how one thing interacts with another, how adjusting one thing upsets another etc., etc.
With the long links dropping to the ARB a race set up could easily be made adjustable by moving the pick up points on the bottom end of the drop links.
gareth
agreed.
maybe fitting a cylindrical adaptor to the end of the standard ARB that allows a large rod end bearing to be moved back and forth? would need a big rod end though to go over the whole ARB.
buster
thanks guys,i'll fit the m3 one.
Gareth,the mount on the strut is fairly chunky so if you do make one make sure its beefy enough.
gareth
not a problem!!!
