M42 missfire
Dan318-is
Post Fri Feb 09, 2007 12:15 am
My car has recently been missfiring but i narrowed it down to a gaping whole in my inlet manifold gasket and IVC hoses. These have since been changed and now it idles perfectly and the exhaust gases smell normal; the plugs are also the correct colours upon inspection
however, under heavy load, and usually in first and second, the car intermitantly seems to missfire. For instance, if i was doing 3000 revs in 3rd, and floored it, or was cruising in fifth and dropped a gear and floored it in fourth, the car would not missfire. However, if i open the throttle up in first gear while in neutral, or in second an i give it a lot of beans it will missfire, although its only occasionally in second that it does it; no matter were i am or what i am doing it i go over half throttle in first it always missfires.
I have changed the TPS, brand new temperature sensor from bmw, both crank and cam sensors are giving the correct readings, all four leads are giving the correct resistance, there is no more air leaks, the ECU is standard and all four coilpacks are giving the same reason.
Could an air flow metre or failing fuel pump really cause this? im on the verge of giving up!
Morat
Post Fri Feb 09, 2007 11:34 am
misfire or pinking?
Dan318-is
Post Fri Feb 09, 2007 11:45 am
Im pretty sure its a missfire; there is no reason for it to be pinking; the engine is running about 2 clicks below halfway at all times. The timing hasnt bene messed around with etc. what bugs me is that its only in first gear mostly :?
toby
Post Fri Feb 09, 2007 12:56 pm
I had a similar problem on an old car and the plugs looked ok but after changing them the misfire went. Maybe the poor burning while an air leak is there messes with the plugs. I'd change the plugs just to take them out of the equation.
Dan318-is
Post Fri Feb 09, 2007 2:49 pm
hmm good point; il change them at the weekend and see what happens!
bennyboy
Post Fri Feb 09, 2007 6:19 pm
could dodgy vac hoses cause this? Mine misfires when i touch the throttle, like when pulling away in first. i've not long had plugs, oil... Ran better but still not quite perfect.
16V IS engine!!!
Dan318-is
Post Sat Feb 10, 2007 12:27 pm
It could do i suppose but u have jsut replaced all my vacuum hoses and inlet manifold gaskets and jubilee clips etc etc. What happens when you floor yours in first? Im going to change the plugs in a mo
Dan318-is
Post Sat Feb 10, 2007 6:11 pm
Changed the spark plugs for some brand new ngk r1's earlier and it seems to have fixed it! the first easy fix i have ever had on my car; it drove fine earlier so we shall see in the coming days thanks guys
Post Sat Feb 10, 2007 6:18 pm
Dan is that a picture of you in your avatar?
Demlotcrew
Post Sat Feb 10, 2007 6:41 pm
:teehee:
Dan318-is
Post Sat Feb 10, 2007 6:45 pm
Simon13 wrote:Dan is that a picture of you in your avatar?
old :twisted: no its katie melua. She'd never set eyes on you so go away!
Ant
Retired Team Member
Retired Team Member
Post Sat Feb 10, 2007 6:52 pm
old no its katie melua.
Looks like she cant get the roach in :lol:
Dan318-is
Post Sat Feb 10, 2007 6:54 pm
you cheeky dog! i think im going to have to change it as im getting abused daily :(
Chris-W
Post Sat Feb 10, 2007 6:57 pm
I'd always thought it was Jonny Depp....
Dan318-is
Thats it! :cry:
stuartgallafant
Post Sun Feb 11, 2007 12:22 pm
Chris-W wrote:I'd always thought it was Jonny Depp....
:lol:
dan, your car is f*cked... just sell it!!!!
just kidding big boy! i'd change the plugs mate. get a nice set of ngk's in there...
