step by step guide for bleeding heater system?
spence_star
Post Thu Feb 08, 2007 6:13 pm
hi guys does anyone have a guide for dummies like me? with pictures etc?
Returned after many years out.
wildeian
Post Thu Feb 08, 2007 7:12 pm
What engine???
liam012
Post Thu Feb 08, 2007 7:18 pm
park the car pointing uphill a tiny bit
turn heater valve on dash to hottest setting
if you like drive left wheel on to the kerb
fill resovoir almost to top and massage all the pipes
undo the thermo housing screw and massage what air you can out (i find it heops to have a friend working the top two hoses together and not releasing tilll you tighten screw again).
fill resovoir to very top
remove top hose from bulk head and let the water gush out a bit and refit quickly
again open thermohousing scvrew and massge some more air out if needed
close screw
start car
when you think the thermostat opens loosen screw massage pipes tighten screw
put resovovoir cap back on and let system pressurise/come up to temp
loosen screw let air come out .ie only water then tighten screw tighten screw
that should do the trick - your coolant should be around the correct level at this stage if not let car cool and top up.
it sounds over complicated but one you do it and get on with doing it that way not faffing about its a very quick and easy 10 min job
good luck
spence_star
Post Thu Feb 08, 2007 7:36 pm
Nice one Liam.
Wild its an M20
