Plumbing in a hydraulic handbrake
Two_Sheds
Post Wed Feb 07, 2007 12:30 am
Right, very sorry for posting another ignorant question - I've bought myself a hydraulic handbrake for my (pre facelift) '87 325i track car, and I'm tying myself in knots with confusion about how to install it. I get the theory that one end goes to the master cylinder and the other to the rear brakes before they split, but I'm not sure where that is on my car. Referring to RealOEM:
I presume I plumb it in to the master cylinder end where the two "10s" join into 1 (is there a t-piece there, or do I have to cut the pipe?!), then plumb the braking end into the 3 way connector where the connection from the front goes in (i.e. the one closest to the right)? Does that sound about right?
The only thing thats confusing me is that when I looked under the car briefly, it looks nothing like that! IIRC, theres 3 lines heading towards the back, and they look like they start at different places! (I only had a brief look, I was too knackered after spending ages doing the z3 shifter conversion). Whats going on?! I'm dead confused, any help would be gratefully received.
Turbo-Brown
Boost Junkie
Post Wed Feb 07, 2007 8:14 am
I'm not 100% sure, but I think that if you plumb directly into the brake lines to the rear of the car, neither the hand brake or the rear brakes would work as applying the handbrake would cause fluid to move into the main brake resevoir, and applying the foot brake would cause fluid to flow into the handbrake resevoir.
The mastercylinders are kind of open between the output and the brake pipe when there's no pressure being applied to the pedal (or brake lever) When you press the pedal, the first thing that happens is that a tiny little valve closes in the MC and after that, the main piston starts to force fluid down the pipes.
Two_Sheds
Post Wed Feb 07, 2007 1:20 pm
Turbo-Brown wrote:When you press the pedal, the first thing that happens is that a tiny little valve closes in the MC and after that, the main piston starts to force fluid down the pipes.
Surely if thats true, then if the HH is plumbed in between the master cylinder and the rear brakes, when the handbrake is pulled, the valve in the master cylinder on the handbrake closes, not allowing any more pressure from in front of it (i.e. the car master cylinder), but also forcing pressure backwards, only to the rear wheels? Thats why I've heard if you get on the brakes at the same time as the hydraulic handbrake, the brakes can be really stiff. As far as I can tell, hydraulic handbrakes have been plumbed in this way since they were invented, so I don't know why the E30 would be any different.
I'm still completely bewildered by the 3 lines running to the back of the car though, anyone have any suggestions?
Picture (look on the right):
Turbo-Brown
Boost Junkie
Post Wed Feb 07, 2007 1:37 pm
As I say, I'm not 100% on that, but my (quite probably incorrect) feeling is that the little valve is pulled open by the release spring.
Thinking about it, when you press a piston back into the caliper the fluid level rises.
e21Jason
Post Wed Feb 07, 2007 1:49 pm
Hi
On most rally cars you run a split pedal box with one master cylinder for the front, one for the rear, and the hand brake is tee'd into the rear brake circuit just likr having two mater clyinders in parrell.
Jason
Turbo-Brown
Boost Junkie
Post Wed Feb 07, 2007 1:58 pm
On the subject of three lines to the rear of the car, one will be fuel feed, one fuel return and the last one the brakes.
Two_Sheds
Post Wed Feb 07, 2007 2:09 pm
Ahhhhhh, god what a thicko I've been. Like I said, I only had a quick look. Magic, will get all over this next week then. Cheers!
Post Wed Feb 07, 2007 8:37 pm
Turbo-Brown wrote:On the subject of three lines to the rear of the car, one will be fuel feed, one fuel return and the last one the brakes.
So what happened to the tank vent line?
Turbo-Brown
Boost Junkie
Post Wed Feb 07, 2007 8:52 pm
You've lost me dude? :)
Ant
Retired Team Member
Retired Team Member
Post Wed Feb 07, 2007 8:59 pm
pre facelift, should be vented by the pump and dampner, has been on the last 6 I was underneath :lol:
only the post 88 have the purge valve provision and the ventline plumbed back to the engine bay iirc
There are four pipes running front to back on an E30.
Turbo-Brown
Boost Junkie
Post Wed Feb 07, 2007 10:31 pm
Are there? There's not on my Brown one, and there doesn't look like there is in that piccy up there.
Is the 4th one to go to a charcoal cannister or something usually?
m-dtech
Unapproved Trader caution
Post Wed Feb 07, 2007 11:08 pm
Turbo-Brown
Boost Junkie
Post Thu Feb 08, 2007 2:06 pm
Yay! I wasn't completely wrong :D
M3Compact
Post Thu Feb 08, 2007 3:42 pm
As above, simpy plumbing it in the rear brake line is fine, pedal pressure flows through and lever pressure doesn't 'back flow'.
How are you mounting the cylinder? If you're mounting it vertically, mount it on flexible/braided pipes.
They won't bleed through properly when vertical, you need to bleed it horizontally and then mount it.
You need to keep a mechanical parking brake for MOT.
