Warm start problem
bluesheenadog
Post Wed Feb 07, 2007 7:46 pm
Could the blue sensor be at fault for not starting when warm? Starts first time
when really cold minus 3 this morning and had stood for 4 days!! Ten minutes later did not start for a good few seconds cranking about 15 seconds but feels
like hours.
Other suggestion fuel pressure regulator. Pump & relay both replaced.
Really would like some help.
Post Wed Feb 07, 2007 7:54 pm
Blue temp sensor is prime suspect for any temperature related problem.
Leaking injector would also cause this problem.
bluesheenadog
Post Wed Feb 07, 2007 9:07 pm
Thank you Brian,
I will change thsi tomorrow weather permitting!!
Post Wed Feb 07, 2007 9:13 pm
If this is a six cylinder car, problems with the injector loom connector under the inlet manifold can give the same effect as a dud blue temp sensor.
bluesheenadog
Post Wed Feb 07, 2007 9:14 pm
No it's an '88 318i,
