For those with M50 conversions........
m-dtech
Unapproved Trader caution
Post Mon Jan 15, 2007 6:34 pm
I have read the m50 developments thread and thought id start this......
Please post your spec..........
Engine
Gearbox
Prop
Engine Mounts
Brake Servo
Post Mon Jan 15, 2007 8:17 pm
Engine - M50B25 Non Vanos
Gearbox - Gettrag (250?) from E36 325i
Propshaft - E30 325i
Engine Mounts - E28 M535i
Servo/master cyl - Renault Clio :o:
Rear diff - 3.25:1 M3 LSD
NEXT!! :)
Eddy
Post Tue Jan 30, 2007 9:00 pm
Engine: M50B25 Vanos edition
Gearbox: E34 short ratio
Prop: E30 325
Engine Mounts: custom,very hard rubber
Brake Servo: golf 2, 1.3l...
Diff: small casing,3,91,mig spec :D
next....
Building my ultimate drift E30....
eko
Old timer
Post Tue Jan 30, 2007 9:10 pm
Engine: M50B25 Non vanos
Gearbox: E34 M50/E36 gear linkage and selector
Prop: E36 328i with E30 centre bearing
Engine Mounts: E28 M5
Diff: 3.46 open
Radiator; E30 318is
Elec fan; Mitsubushi Galant 24v
Post Sat Feb 03, 2007 1:26 pm
Engine: M50B25 Tu, Ex E34
Gearbox: E36 320i
Prop: E30 325
Engine mounts: Probably E30 325
Brake servo: Standard E30, moved sideways
Diff: E28 525e,open
Radiator: E30 325
Elec fan: E34 aircon.
Conversion number two just starting.
Engine: M50B25Tu, Ex E36 (unless a B28 comes along)
Gearbox: E36 325i
Kedge
Post Sat Feb 03, 2007 1:33 pm
Just wondering, is it at all possible to use a vanos engine? Thinking more M52B28 at the moment though!
Instagram - Kedge85
Post Sat Feb 03, 2007 2:12 pm
Kedge wrote:Just wondering, is it at all possible to use a vanos engine? Thinking more M52B28 at the moment though!
Wouldn't consider using anything else! The difference in grunt from low revs is considerable.
Vanos is all self contained and causes no extra work at all.
EWS complicates things a bit, but no major problems as long as you have all the matching bits.
iKst
Post Tue Feb 06, 2007 6:08 pm
Engine: M50B25 from E34
Gearbox: E36 325 gearbox
Prop: E36 325
Engine Mounts: custom, from hard rubber.
Brake Servo: stock E30 servo in original position
Diff: E28 LSD
Radiator: the large one from E34 with air-con and electric fan.
brian325i
Post Sat Feb 24, 2007 4:54 pm
planning on doin this as soon as i can locate an engine..was planning on using m50b25 from 525..putting into e30 318is..any link to step by step..i have fair idea but it be nice to see it done step by step..any link???sorry for off topic post but hopefully soon i will fill in the topic of this thread :D
thanks in advance brian
m-dtech
Post Sat Feb 24, 2007 5:48 pm
brian325i wrote:planning on doin this as soon as i can locate an engine..was planning on using m50b25 from 525..putting into e30 318is..any link to step by step..i have fair idea but it be nice to see it done step by step..any link???sorry for off topic post but hopefully soon i will fill in the topic of this thread :D
thats what i have just done mate,
Gearbox: E30 318IS gearbox
Prop: E30 325
Engine Mounts: M20B20
Brake Servo: Renalt Clio
Diff: Standard E30
Radiator: Standard late E30 type.
brian325i
Post Sat Feb 24, 2007 6:04 pm
whats the story with all the different engine mounting options?? e28 m5.. m20b20??whats difference??
will the e30 318is gearbox match m50b50 flywheel??
is it nippy :D
Post Sat Feb 24, 2007 7:42 pm
m-dtech, do you mean rubber mounts or mounting arms?
m-dtech
Post Sat Feb 24, 2007 7:48 pm
rubber mounts mate, i used the e36 arms.
m-dtech
Post Sat Feb 24, 2007 7:50 pm
brian325i wrote:whats the story with all the different engine mounting options?? e28 m5.. m20b20??whats difference??
is it nippy :D
best option is to use the e36 alloy engine mount arms and, e30 2.0/2.5 engine rubber mounts.
yes the 318is gearbox mates up with m50 block and you can use m50 clutch, flywheel and starter motor.
m
Tom944
Post Sat Feb 24, 2007 10:25 pm
Prop: E30 325e
Brake Servo: E30 325IX
Diff: 3.25 LSD
Radiator: E36 325i
Elec fan: Spall
LHD btw.
E30 M50B25 racer soon-to-be E30 S50B30 racer
eko
Old timer
Post Sun Feb 25, 2007 12:46 am
Difference is strength!
I only used E28 M5 ones cause at the time of my conversion thats what i read someone else had used.In hindsight id have probably just used the M50/M20 ones though!
is it nippy :D
As said best bet is to try and blag a passenger ride!
I can only speak for the M50.
Plenty of power when needed,sound better(IMO) than any M20 ive heard when under load and good on fuel too winkeye
Im planning on doing a vanos conversion soon,maybe a 2.8 if funds allow.
Just got to find a donor car to replace my current one with :)
TheDutch
Post Sun Feb 25, 2007 5:14 pm
This is a really helpful thread already, but would be even better if people could indicate what they've gone for exhaust wise, and/or any changes they'd make if they were doing the conversion again.
Kedge
Post Sun Feb 25, 2007 5:46 pm
Been discussing this today and i've decided to use the M50 rather than the M52. Going to use my iS gearbox, will i not be able to keep the same prop or will i still need to use the 325 prop? Going to try and find a single vanos engine, will this still be a simple plug in conversion using the E34 loom?
Eko: when you say good on fuel how good are we talking? :wink:
Is the M50 2.5 much faster than an M20 2.5?
Instagram - Kedge85
eko
Old timer
Post Sun Feb 25, 2007 5:53 pm
Kedge wrote: Eko: when you say good on fuel how good are we talking? :wink:
Mine averages anywhere between 40 od - 60 odd miles per £10!
Which i dont think is bad considering its constantly used for school run/shopping etc so mainly local driving.
Does get a good thrashing now and again though winkeye
Post Sun Feb 25, 2007 6:27 pm
On £20 of petrol -
100 miles town
150 on a good motorway run (not above 70mph winkeye )
For exhaust info search the threads, its pretty standard.
M52 manifold chopped and welded.
Eddiejt2
Post Sun Feb 25, 2007 6:31 pm
:o If we say petrol is 90p per litre then that's only 16-24mpg. Not good. I thought the M50 was better on fuel than the M20?
Post Sun Feb 25, 2007 6:32 pm
I can get 30mpg all day on m-way
Also depends on what rear diff you use
jmc330i
Post Sun Feb 25, 2007 6:34 pm
Kedge wrote:Going to use my iS gearbox, will i not be able to keep the same prop or will i still need to use the 325 prop?
Thats the only bit Im not sure about and is whats stopping me converting my touring - I would be using my 318i box, but Im not sure on the prop needed.
As I understand it, you will need the 325i prop as its shorter than the iS prop - the gearbox will be moved backwards when fitted to the M50, compared to the M40/M42.
James
'91 325i Sport
'93 318i touring 16v
eko
Old timer
Post Sun Feb 25, 2007 6:35 pm
Should have said,thats around town.
Car is mainly used by my misses for twice daily school run and shopping so barely even gets warmed up before being parked again!
On motorway it is spot on,as Dans,i get about 150ish miles to £20!
jmc330i
Post Sun Feb 25, 2007 6:42 pm
DanThe wrote:On £20 of petrol -
100 miles town
Thats about what I get from my M20 around town, and I dont really have a light right foot. So with the extra go from the M50, the conversion would be worth it.
Eddiejt2 wrote:I thought the M50 was better on fuel than the M20
IIRC from figures I read ages ago, the E36 325i (M50) is a little bit worse on fuel than the E30 325i, its the 328i (M52) thats better on fuel than both M20 and M50.
James
'91 325i Sport
Post Sun Feb 25, 2007 7:16 pm
jmc330i wrote:, the E36 325i (M50) is a little bit worse on fuel than the E30 325i,
Don't believe this! The M50 is a more efficient engine than the M20, and for equal performance from the car, should return better fuel consumption.
Diff ratios could be a factor.
jmc330i
Post Sun Feb 25, 2007 7:23 pm
Cant remember where it was quoted now, but I do remember reading the E36 325i was worse - it was only 1-2mpg either way mind you.
The 328i was quoted to be quite a bit better, probably down to its restricted bits and bobs.
James
'91 325i Sport
Post Sun Feb 25, 2007 7:30 pm
jmc330i wrote:The 328i was quoted to be quite a bit better, probably down to its restricted bits and bobs.
Buckets of torque and vanos more like winkeye
m-dtech
Post Sun Feb 25, 2007 7:40 pm
IS box fits sweet as a nut.
M50 pushes the box back further, so you need the shorter prop from a 2.0/2.5
Shorter gear linkages also.
jmc330i
Post Sun Feb 25, 2007 7:42 pm
I was just wondering if it would still be better on fuel if the 2.5 inlet etc was fitted??
James
'91 325i Sport
jmc330i
Post Sun Feb 25, 2007 7:45 pm
m-dtech wrote: M50 pushes the box back further, so you need the shorter prop from a 2.0/2.5
ETK lists the 325i prop as 1489mm and the 320i prop as 1526mm. Which did you use?
When you say shorter gear linkages, do you mean 325i or modded ones?
James
'91 325i Sport
eko
Old timer
Post Sun Feb 25, 2007 7:50 pm
So the iS clutch and flywheel is used?
Take it the flywheel needs redrilling to fit the M50 crank?
m-dtech
Post Sun Feb 25, 2007 7:53 pm
320i prop is the daddy to use. :)
eko
Old timer
If using the iS gearbox what ratio diff can be used?
3.64/3.73?
m-dtech
Post Sun Feb 25, 2007 7:54 pm
i used the m50 clutch and flywheel, it fits in the gearbox no problem. i might go for an m20 arrangement at a later date.
m42 flywheel is same fitment i believe.
