LSD oil
oze30
Post Mon Feb 05, 2007 10:35 pm
Hey all!
Just acquired my new diff.. BUT it has no OIl.
What oil do I need and how much of it will I need?
Am I better off filling it off the car (more weight) or on the car (difficulty???)
Cheers!!
SPADGE
Post Mon Feb 05, 2007 10:38 pm
Decent qaulity Hypoid gear oil
Approx 1.7 litres
Fill it out or in it makes no odds
You could have asked me this in the morning btw :mad:
oze30
Post Mon Feb 05, 2007 10:42 pm
yeah.. but I'll grab it on the way there! What brand?
SPADGE
Post Mon Feb 05, 2007 10:45 pm
oze30 wrote:yeah.. but I'll grab it on the way there! What brand?
One you have heard of ie 'Castrol' and certainly not 'Costco' :P
Theo
oze30
Post Mon Feb 05, 2007 10:48 pm
What if its castrol from costco?? winkeye winkeye
wholesale is where its at!!!
SPADGE
Post Mon Feb 05, 2007 10:54 pm
Col i can get a gallon for the price of that stuff at Peter Lloyd so leave it with me :wink:
Post Mon Feb 05, 2007 10:59 pm
the diff needs 1.9 litres but 2.0 is fine.
you can use normal castrol diff oil for open diffs and then add an LSD additive with it. You can get the additive from vauxhall. This is a bit cheaper and just as good as forking out for LSD oil
hth
SPADGE
Post Mon Feb 05, 2007 11:07 pm
Simon13 wrote:the diff needs 1.9 litres but 2.0 is fine
Simon knows better than the original BMW handbook Col :eek:
I'll have a word with my old mate Berni (gearboxman.co.uk) in the morning and see what he recomends before you go shelling out for supposed special LSD oil. I'm pretty sure he always said to use atf in cossie lsd's so i see no reason why that wouldn't be ok for a bmw lsd.
M3Compact
Post Tue Feb 06, 2007 1:35 pm
Cossies have viscous LSD units, don't use ATF in a BMW LSD.
Castrol SAF XJ if you want fully synthetic, Castrol B373 if you want to save money. (£36 v £10 for 2 litres.)
beem
Post Tue Feb 06, 2007 1:40 pm
Castrol B373 here too!
Karan
Post Tue Feb 06, 2007 5:49 pm
just get it from bmw
john325tewerin
Post Tue Feb 06, 2007 5:53 pm
I got mine from the dealer at £12 per litre! It's longlife so you may never need to ever change it.
Post Tue Feb 06, 2007 5:57 pm
Spadge you are quoting a small case diff, a medium case for a 325i is 1.9 litres
bmw lsd's are clutch pack so as said atf is no good.
i can only try to help :?
E30Mark
Post Wed Feb 07, 2007 12:01 pm
Keep it on topic guys :D
PM for details
