High idle on m40
SPADGE
Post Tue Feb 06, 2007 10:19 am
Hi guys
The 318 tourer i have idles at approx 1300 rpm
It runs fine otherwise.
How do i adjust this idle or is it controlled by the ecu?
If yes to the above could it be a sticky iscv or something else?
Cheers Spadge..
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Tue Feb 06, 2007 10:36 am
I'm no expert but it can be a problem with the ICV, but other suggestions are the Throttle position sensor, or something as simple as the cold start sensor.
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
E30Mark
Post Tue Feb 06, 2007 10:44 am
Check the throttle cable isn't too tight...
The idle is set by the ECU when the TPS is correctly set.
PM for details
SPADGE
Post Tue Feb 06, 2007 7:41 pm
Thanks guys i'll have a look at what you have both suggested
Cheers Spadge...
