5 green lights on and the inspection light??
e30_Turbo
- Boost Junkie
Hello all,
Got a wierd one here, when the cars in igntion position 2 I get the 5 green lights, which is normal but now I get the inspection light too, the actual orange inspection light, the one that says "inspection"
So does anyone know what this light on the dash is govenerned by?
If it's a earth issue that would make sense but I'm stumped.
Thanks, Mark.
Thanks, Mark.
E30Mark
The inspection light comes on every 12 months, independent to the service lights. It's to indicate your vehicle needs a yearly inspection...
PM for details
PM for details
Absolutely normal. Doing what it's supposed to do.
e30_Turbo
- Boost Junkie
Thanks guys!
Thing is this "inspection" light was flickering on and off like it had a bad connection for the last few weeks, I'm currently pulling wires and upgrading/soldering to pinpoint an ignition issue, I just wondered if a duff connection could cause this also?
I'm 90% convinced I've either pulled a wire or nudged a connection when rewiring the ECU but tbh I'm clutching at straws......
May have to bite the bullit and buy another loom just to be sure...... ow well
Can't see it being anything to do with the engine loom. Possibly a body loom or fuse (10) problem, but I doubt it.
Most likely the actual lamp has blown and the broken ends of the filament are touching together.
orangecurry
sorry to disagree with Brian/Mark
but isn't it JUST the 'clock' symbol that appears every 12 months? Or does the word 'Inspection' appear as well?
Handbook says clock and inspection lights should come on together.orangecurry wrote:sorry to disagree with Brian/Mark![]()
Jon_Bmw
- Dangerous when thinking
I got the clock symbol on mine, but not the inspection word. There is a tool that you can reset it with. Or shorting two wires in the diagnostic plug for a certain period of time iirc. (1-7 come to mind, but its been along time
Guess mine was half broken then, as i never saw the inspection word lit.
E30Mark
Hand book says Clock symbol in conjunction with inspection shows that an annual inspection is due.
I can't remember if one or both symbols used to come on in my past E30's.
PM for details
PM for details
The three lights above the LEDs are ordinary incandescent bulbs, and blown ones are quite common.
m3gt
I have thi lighton at the moment and the inspection was done a week ago.....will it automatically go off???
Regards
M
Regards
M
orangecurry
No.
Whoever did the 'inspection' should have reset the lights.
m3gt
the green indicator lights were reset...1 green light has gone out and 'inspection' light and 'clock' sybol is showing.
Regards
M
Regards
M
No connection at all between the green LEDs part of the SI display and the clock symbol part.
gareth
mine only shows the inspection and clock but no LEDs. it won't reset either... duff SI board?
feens
I Have oil service light clock inspection lights on aswell as orange led all came on together apart from the clock and inspection symbols! Is there something else i should look at? The car has boon recently serviced aswell!
That's an "allowable" combination, so try resetting them.feens wrote:I Have oil service light clock inspection lights on aswell as orange led all came on together apart from the clock and inspection symbols! Is there something else i should look at? The car has boon recently serviced aswell!
How many green LEDs were lit before it was "serviced"?
If it won't reset, then it's duff, or at least the batteries are.gareth wrote:mine only shows the inspection and clock but no LEDs. it won't reset either... duff SI board?
feens
There was only one green lit BrianBrianmoooore wrote:That's an "allowable" combination, so try resetting them.feens wrote:I Have oil service light clock inspection lights on aswell as orange led all came on together apart from the clock and inspection symbols! Is there something else i should look at? The car has boon recently serviced aswell!
Next in the sequence after one green LED is orange LED + oil service or inspection. If the clock light comes on as well, then the inspection light will also come on. In a few days I expect the red LED will be on as well.
Just reset the lot and follow the lights for your service intervals.
feens
your a legend! now for the clanger! How do i reset them without the Re-set Tool?? Cheers againBrianmoooore wrote:Next in the sequence after one green LED is orange LED + oil service or inspection. If the clock light comes on as well, then the inspection light will also come on. In a few days I expect the red LED will be on as well.
Short pin 7 of the diagnostic socket to earth and switch the ignition on.feens wrote: How do i reset them without the Re-set Tool??
Use the search function for exact details.
feens
Thanks a million Brian will give it a shot tomorow hopefully that will sort it!
