I went to pick up the car today with the intention of doing the gearbox bush overhaul, but it wouldn't start. I disabled the immobiliser/alarm but the central locking didn't unlock, so I got into the car using the key. When I tried to start it up, all the dash wanring lights came on, and the rev counter flickered up and down between 0 and 2.5k revs, but that was all - nothing turning over and no noises.
Is this simply a flat/dead battery, or could it be something more sinister? I washed the car about 2 weeks ago and noticed some strange things, like one indicator stopped working and the car would periodically lock and unlock itself, but I assumed it had dried properly, as it was fine by the time it had done the 5 miles to its lockup.
Any thoughts?
Car won't start - electrical problem?
Starter not turning over at all? Take the cover off the diagnostic socket and short socket 14 to socket 11 with a piece of wire. Should make engine turn over, and start, if the ignition is on.
If it does,(turn over), then you probably have an immobiliser fault.
If it doesn't, turn the ignition and headlamps on. If the lights are bright then check out the earth strap between the body and engine.
Two_Sheds
Before I read your reply, I'd fired off with some jump leads to try and sort it - it worked and the car started, its now back at home with the battery charging (tested it first and charge was exceedingly low). I reckon that when I washed it, it possibly caused a short circuit somewhere that has drained the battery while its been sat. I think I'll disconnect the battery while its stored in the lockup, until I can get more time to investigate it (if it happens again).
Thanks again for your reply Brian.
Now I'm off to do the gear linkage bushes - looking forward to attempting to drop the gearbox and prop. Not.
