tips on removing the aircon set up
dark_sounds
Sun Feb 04, 2007 12:13 pm
advice, tips, partlist for full air con set up,
much appreciated guys i need all this stuff out!
stuartgallafant
Sun Feb 04, 2007 12:18 pm
the receiver dryer should be vented to atmosphere o longer than 24 hours, otherwise its f*cked
other than, good luck!! and DONT let your face get anywhere near the refridgerant
dark_sounds
Sun Feb 04, 2007 1:56 pm
lol!! you ever removed one?
i know about the 24 hour thing, thats why im waiting for a buyer before i remove, so it can be removed, put some bungs, block it up seal it and give it.
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
stuartgallafant
Sun Feb 04, 2007 2:07 pm
not from an E30, but i've work on car air con systems, and refridgerant is not fun
someone i work with had a blast in the face with the tinniest little bit, and he said it felt like his hold head and throat swelled up. he couldnt breathe properly and had to go home via the hospital!!!
the only proper way of releasing the refridgerant from the system is to have it 'recovered' using a machine, and even then, there is residual pressure
miniblob
Sun Feb 04, 2007 2:22 pm
Ali, how much you looking for the full a/c kit??
I could be tempted!!!
Stu could get the bits off ya, run to Tee's place and fit it up for me before the receiver dryer thingy gets fooked winkeye
327 Touring with bass!!!
stuartgallafant
Sun Feb 04, 2007 2:23 pm
yeah, im sure i'd love to...
miniblob
Sun Feb 04, 2007 2:29 pm
Ha ha, you love it!!!!! :cheers:
Or maybe i should just stop pushing my luck until everything else is sorted!!!
stuartgallafant
Sun Feb 04, 2007 2:30 pm
miniblob wrote:...Or maybe i should just stop pushing my luck until everything else is sorted!!!
good idea... :mad:
e21Jason
Sun Feb 04, 2007 2:49 pm
Hi
I used to be a refrigeration engineer, and cracking open the lines either sdie of the compressor should vent the system if there is any pressure after that you must have a blockage somewere.
The drier is filled with sillica gell, but i would never reuse one.
The recovery equipment should put the system into a vacumm and leave no gas.
And on an old r12 system NEVER let the gas get near a naked flame it makes Phosgene.
Jason
Sun Feb 04, 2007 4:18 pm
I thought you had to take the car outside, crack one of the pipes open and then quickly run inside and drink your tea :)
Markey
Mon Feb 05, 2007 9:52 am
Is the dryer the condensor?
Is so are they expensive new ?
cliffybabe
Powered by Nelly
Powered by Nelly
Mon Feb 05, 2007 10:26 am
Ali put the big hamer down u know it aint the way forward :lol:
(went round ali's yesterday to pick up some bits and as i pulled up he appeared with a massive hammer :mad: )
Ali its hammer time
miniblob
Mon Feb 05, 2007 6:18 pm
Ha ha ha, mental pic of Ali alongside MC Hammer :lol:
My 4lb club hammer is probably my most used tool!!!!!!
cliffybabe
Powered by Nelly
Powered by Nelly
Mon Feb 05, 2007 6:42 pm
miniblob wrote: My 4lb club hammer is probably my most used tool!!!!!!
u didnt use that to open the tourng boot lid winkeye
ian332isport
Mon Feb 05, 2007 7:50 pm
Markey wrote:Is the dryer the condensor?
Nope, totally different parts.
The condenser is a small radiator style unit that fits in front of the main engine radiator. The dryer is the round bottle thing with 1 or 2 pressure switches on it (fits behind the drivers side headlamp).
Ian.
