help opening the bonnet
cass1_5503
Post Sun Feb 04, 2007 12:44 pm
the battery has gone flat on my dads cabby the keys dont work in the doors how do i open the bonnet from the outside so we can change the battery
cheers
richie
jcjdavis1
Post Sun Feb 04, 2007 1:12 pm
Hi I think there is a hole next to the n/s headlamp that you put a screwdriver in and push a lever,or take out rear number plate light and connect a battery to the wires which will give you power to use your remote.If I am wrong someone will tell me.
march109
Post Sun Feb 04, 2007 1:37 pm
unusaul for the keys not work even if the battery is flat. At least they have always worked on mine, even when I've taken the battery out completely.
As above though I think as your facing the car on the left hand side. between one of the slats in the plastic around the lights you can use a screw driver to open the bonnet. You'll need a torch and a flat head screwdriver with a pretty large head.
buster
Post Sun Feb 04, 2007 1:47 pm
Not a good idea to tell the public about how to gain access to an e30 !!!!
Richie,i will pm you how to do this
jcjdavis1
Post Sun Feb 04, 2007 2:09 pm
Hi I read this on the forum common knowledge me thinks.
cass1_5503
Post Sun Feb 04, 2007 9:12 pm
thanks for the help peeps great help
Post Sun Feb 04, 2007 9:58 pm
Key should work in the driver's door if you lift the handle at the same time.
Alternative is to connect a small battery charger in place of the boot lamp bulb and give the battery a bit of charge.
cass1_5503
Post Sun Feb 04, 2007 11:14 pm
the keys dont fit the door or boot they only work in the ignition i turned out the alarm had given up so wouldnt open the locks
Post Mon Feb 05, 2007 12:17 am
cass1_5503 wrote:the keys dont fit the door or boot they only work in the ignition i turned out the alarm had given up so wouldnt open the locks
Why do people run cars in this sort of condition????
Door and boot locks are probably original, so get a key from your dealer.
