battery keeps dying
ag-1982
Post Sun Feb 04, 2007 8:59 am
I keep having to charge my battery up as when i put it in the car it starts ok for the first few times then just goes flat again.
I started it yesterday a few times and each time it turned over really strong, then all of a sudden it died and there was nothing.
Any ideas?? :(
fuzzy
He who sleeps with "Gingers"
Post Sun Feb 04, 2007 9:08 am
could be the alternator .if its dying very soon after charging without any electrics being on id guess it was that.get your battery checked at your local kwik fit first though or try another if you have access to one.also check the earth strap to the alternator.
Post Sun Feb 04, 2007 10:15 am
Ignition light!
ag-1982
Post Sun Feb 04, 2007 11:00 am
All the lights come on and everything runs fine, but then it goes dead its as if there is something draining the life out of the battery but i cant find anything
ag-1982
Post Sun Feb 04, 2007 4:40 pm
Charged the battery again this morning everything was running fine untill i went to open my rear passenger side window.
All the light were dimming and the battery just drained itself within seconds :x
Could this be a short and if so how do i sort it out.
Or is there some way i can recondition the alternator rather than buying a new one.
Post Sun Feb 04, 2007 5:17 pm
If your battery was fully charged, then nothing can drain it in seconds unless accompanied by large quantities of smoke and possible flames. Sounds like you have a dud battery.
Measure the voltage across the battery with the engine stopped, and with it running.
