Tappy tap tap
mull3tt
Post Sat Feb 03, 2007 5:57 pm
Hi all, i got a tapping head (318i), When i drive its always there, but can sometimes stop for a few seconds and then come back.
I have read a few threads on here about it and thought ill change oil and clean the spray bar and see if its any better.
I cleaned the spray bar as the outer two holes were blocked, fitted it and changed the oil to some 5w40 synth. no change :(
I coudln't see any way of adjusting the gaps but it was dark :?
Was going to try a new spray bar just to make sure, and try turning it over with no rocker cover on to see if its working properly and the oil pump is working too.
Question is can they be adjusted? and/or can the oil pump not be working right as the tap can go for a few seconds now and again.
Thanks for any help
Chris-W
Post Sat Feb 03, 2007 6:01 pm
They're self-adjusting hydraulic tappets. Can be replaced but it's an expensive cure.
mull3tt
Post Sat Feb 03, 2007 6:02 pm
How expensive we talking?
mull3tt
Post Sat Feb 03, 2007 6:22 pm
Cant they be taken out and cleaned or can new kits be bought and fitted myself?
smithy318i
Post Sat Feb 03, 2007 6:24 pm
mull3tt wrote:How expensive we talking?
M40 Camshaft Kit costs £199.00
M40 Camshaft Kit includes:1x Camshaft,8x Rocker Arms,8x Hydraulic Tappets.
This is the Minimum you must replace when fitting a replacement for a noisy camshaft,otherwise you will not cure the problem.
mull3tt
Post Sat Feb 03, 2007 6:40 pm
found it, thanks
mull3tt
Post Sat Feb 03, 2007 7:04 pm
Is it a case of the tappets need cleaning or are they buggered? Can they be cleaned and reused? (student)
Dave_M3
Post Sat Feb 03, 2007 9:11 pm
As far as I know the only way of gettin rid of the annoyin tap is 2 fit new ones :(
But is it very loud, cos its completely harmless, this can start happenin on the m40s with as little as 50 thousand miles
mull3tt
Post Sat Feb 03, 2007 9:30 pm
yeah its quite loud, i know its harmless but sounds like im driving a shitter :( maybe no exhaust will drown the sound out haha
Post Sat Feb 03, 2007 9:41 pm
mull3tt wrote:Is it a case of the tappets need cleaning or are they buggered? Can they be cleaned and reused? (student)
If they're clogged, then cleaning will improve them. If they're just worn, then cleaning will make them worse.
I improved one of my E30s considerably by running it with a cheap diesel oil for six months, and then refilling with a decent mineral oil.
Best cure is to find an engine that doesn't knock and swap engines. M40s only cost slightly more than £0.
OBs
Post Sat Feb 03, 2007 9:46 pm
Cheap alternative = 1 x Bag of Sawdust!
Ive got a M10 (160k) tappety as buggery, but the blowing exhaust covers that up winkeye
Dave_M3
Post Sun Feb 04, 2007 2:34 pm
yeah its quite loud, i know its harmless but sounds like im driving a shitter maybe no exhaust will drown the sound out haha
Ya, I know the feeling, my 316 is the same, sound reminds me of an old ford fiesta at times :o: . Was goin 2 get a load exhaust but now thinkin of the best cure availible, selling it and getting an IS winkeye
mull3tt
Post Mon Feb 05, 2007 10:50 am
Right i can get the lifters for about £55, rockers about the same. If i was going to buy them seperate would it be worth getting a high-lift cam or not? And where/which?
mull3tt
Post Tue Feb 06, 2007 12:21 pm
High-lift cam for m40? worth it or not? :?
eltel
Post Tue Feb 06, 2007 2:09 pm
when i started out in my 318 with the same annoying tappety noise i was like you dead set on curing the problem..but the bmw dealer technicians told me that it wasn.t worth replacing the old ones with new ones as in their experience the new tappets began rattling only a few thousand miles later anyway....something to think about?
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
geo1400
Post Tue Feb 06, 2007 2:21 pm
eltel wrote:new tappets began rattling only a few thousand miles later anyway....something to think about?
Thats very much the case. I changed mine at 100,000 miles and at 112,000 it's starting to bug me again. It's not loud at all but I can JUST hear it. I reckon by 130,000 it'll be back to as bad as it was. (with regular servicing)
With mine, the camshaft was very worn. You could actually see the scoring on the lobes. It was VERY satisfying starting her back up after the change though! :D
Geo1400
mull3tt
Post Tue Feb 06, 2007 5:00 pm
Yeah the lobes are scored on mine too. Aslittle as 12k? thought someone said about 50k :(
dazleeds
old skool raver
old skool raver
Post Tue Feb 06, 2007 5:12 pm
cmon lads
lets have some honesty here :eek:
the only real longterm cure to this problem is to fit a 6pot :duck: :snigger:
www.oldskoolfantasy.co.uk
mull3tt
Post Tue Feb 06, 2007 5:14 pm
haha, no time, money or place atm :(
dazleeds
old skool raver
old skool raver
Post Tue Feb 06, 2007 5:17 pm
mull3tt wrote:haha, no time, money or place atm :(
may well be worth suffering the noise for a few months and doing the swap tho
bits are easy enough to come across and im sure someone will have some space you could use :D
its gonna cost 200plus every 12k so prob work out cheaper in the long run and think of the grin factor when done winkeye
mull3tt
Post Tue Feb 06, 2007 5:22 pm
True, have to wait til the next student loan suppose :mad:
dazleeds
old skool raver
old skool raver
Post Tue Feb 06, 2007 5:34 pm
OBs wrote:Cheap alternative = 1 x Bag of Sawdust!
winkeye
aahhhh the oldest of oldskool sales tactics :snigger:
geo1400
Post Wed Feb 07, 2007 10:10 am
mull3tt wrote:Aslittle as 12k? thought someone said about 50k :(
Like I said, I can JUST hear... no-one else can hear it but it's there I tell ya!!
Or maybe it's the voices in my head again... 8O
Dave_M3
Post Wed Feb 07, 2007 8:54 pm
Mine has got fairly load arite but has alot to do with the car being driven with a stuck open thermostat when I got it, damage of cold running was already done then, ah well its only my 1st car, lookin 4ward now to selling it and getting an IS :) , wouldnt mind the sound of a 325 with a scorpion :D but I think the insurance company would mind :(
mull3tt
Post Thu Feb 15, 2007 9:14 pm
Dave_M3 wrote:Mine has got fairly load arite but has alot to do with the car being driven with a stuck open thermostat when I got it, damage of cold running was already done then, ah well its only my 1st car, lookin 4ward now to selling it and getting an IS :) , wouldnt mind the sound of a 325 with a scorpion :D but I think the insurance company would mind :(
Think my stat is stuck open too, it just goes over the blue when driving and will go slowly up to half if standing and heaters off. Sound stuck open?
What damage will this cause? just takes longer for the oil to get around so less lubrication from cold?
bmwe30mtech
Post Thu Feb 15, 2007 9:25 pm
When i bought mine it was silent, 10k miles of driving from me and it sounds very tappety, makes people turn arround in town :o: .
A loud exhaust simply makes the tapping worse, it amplified my problem. Im back with a standard exhaust now.
Solution, leave it, turn up the music :? . M40's are not in short supply.
Gortour
Post Thu Feb 15, 2007 9:36 pm
mull3tt wrote:What damage will this cause? just takes longer for the oil to get around so less lubrication from cold?
Pretty much right. But also with the engine never getting up to temperature, the oil never gets that thin and doesn't reach all the nooks and crannies that it would if hotter and thinner.
I have had very good results with an engine flush (Wynns do one). Add it to the oil, run the engine for 5-10 mins and give the car an oil and filter change.
I Slick 50'd mine too - this is where someone says NOOOOOOOOO!!! winkeye
mull3tt
Post Thu Feb 15, 2007 9:40 pm
I did a flush when i changed the oil, no change.
What needs to be changed on the stat then? This is the worst time to have a fooked stat too :(
Gortour
Post Thu Feb 15, 2007 9:44 pm
Some card in front of the rad this time of year may help a bit...
Yeah, I know, Pikey suggestion...
mull3tt
Post Thu Feb 15, 2007 9:51 pm
Lol, how much is some? 50% coverage? or should i just experament?
Gortour
Post Thu Feb 15, 2007 9:57 pm
Running that cold, full coverage. Will still get cold air underneath. Experimentation is the key mate.
mull3tt
Post Thu Feb 15, 2007 9:59 pm
Ok, will try when i get home, thanks.
Btw, doesnt it get soggy with rain? or should i find some proper waterproof cornflake box stuff? :cool:
Gortour
Post Thu Feb 15, 2007 10:21 pm
That's the best idea. Yes it will get wet, so if you can find something that won't be too affected, so much the better.
eltel
Post Fri Feb 16, 2007 4:15 pm
if the engine runs cold it normally uses more fuel!!!!
Post Fri Feb 16, 2007 7:45 pm
gortour wrote:That's the best idea.
I think the best idea would be to change the thermostat!!
