M30 IDLE PROBLEM
gall
Post Sat Feb 03, 2007 8:21 am
Hi,
i've got a problem in that my m30 won't sit at a steady idle, i think the idle is set to low 500/600 rpm.
any ideas what up with it??
cheers
gall.
march109
Post Sat Feb 03, 2007 8:30 am
vacuum leak possibly? tried checking the pipes from the air intake to the engine for splits?
gall
Post Sat Feb 03, 2007 10:33 am
cheers march109,
yeah that was the problem.
any idea what the idle rpm shold be?
how can i change it?
cheers
gall.
march109
Post Sat Feb 03, 2007 10:50 am
replace the affected rubber pipe, bloody hard to find them in good nick second hand. Try the stealers but I've heard horror stories about prices of these, some gaffa tape should do it.
No idea on the RPM though they are usually around 600-700 rpm, my m20 idles at 600, fix the leak and you should fix the idle.
Post Sat Feb 03, 2007 2:16 pm
march109 wrote:replace the affected rubber pipe, bloody hard to find them in good nick second hand. Try the stealers but I've heard horror stories about prices of these, some gaffa tape should do it.
Idle speed is fixed by the ECU, and can only be changed by reprogramming it.
Small increase in idle speed can be achieved (don't know why you should want to, though) by connecting the ECU pin that is switched for aircon.
gareth
Post Sat Feb 03, 2007 5:53 pm
the main M30 air hose i needed was only about £15 / 20 new... but i was given one for free by a splendid fellow 'zoner! (you know who you are... :D )
oze30
Post Fri Feb 23, 2007 10:38 pm
The air hose is part# 13.71.1.707.767 and its 12.43 Not sure if its plus vat or not.. just reading it from my invoice.
Mine's got no leaks, but still idles odd.
Cold start idles way too rich and lumpy. Sounds like an injector not squirting, but mine's not the only m30b35 that's doing it. When it's warm, its fine. not lumpy/rich.
Any ideas?
Post Fri Feb 23, 2007 11:12 pm
If you are sure there's no physical cause, then experiment with a resistor (start with about 2000 ohms) connected across the wires to the blue temp sensor.
This will reduce the amount of cold start enrichment.
oze30
Post Sat Feb 24, 2007 11:35 am
How come it would cause an issue in an e30 when it doesnt in an e34?
nickso
Post Sat Feb 24, 2007 2:00 pm
oze30 wrote:The air hose is part# 13.71.1.707.767 and its 12.43 Not sure if its plus vat or not.. just reading it from my invoice.
Any ideas?
exact same problem with mine.....sometimes it starts like a bag of nails other times it starts perfectly.
im beginning to think its a fuelling issue like brian said. ive changed the fpr as i had one handy but it made no change.
'88 e30 328i M52 track bint.
gareth
Post Sat Feb 24, 2007 10:13 pm
mine is/was spluttery from startup in both the E32 735i and E30. for the fist minure from cold (when idling) it's just a bit lumpy then it sorts itself out. it's something i have to address at some point if i ever get that bored but it never causes a problem with starting. in fact, mine has never failed to start after a very quick burst on the starter motor (less than 1 second, then i let go of the key and it'll be running). even after being dry of fuel when doing the swap, it fired after about 5 revolutions (2 seconds?).
well that's jinxed it!!!! :D
oze30
Post Sat Feb 24, 2007 10:27 pm
gareth wrote:mine is/was spluttery from startup in both the E32 735i and E30. for the fist minure from cold (when idling) it's just a bit lumpy then it sorts itself out. it's something i have to address at some point if i ever get that bored but it never causes a problem with starting. in fact, mine has never failed to start after a very quick burst on the starter motor (less than 1 second, then i let go of the key and it'll be running). even after being dry of fuel when doing the swap, it fired after about 5 revolutions (2 seconds?).
mine was the same. Started on the button after the swap. But cant work out why they do this.
Yet to try the resistor. Going to go to maplin tomorrow and see what happens.
oze30
Post Fri Mar 02, 2007 8:06 pm
So it goes across the wires, not inline with one? I think i biught the wrong ones.. i boutght 200, 270.. might have to return them and try again
