body kits pics wanted
salami
can anyone put some pics up of different body kits pref on a 87 325 as im getting lost with the different ones,thanks
mrLEE30
Ho hum.
click on photo section and browse, alternatively do a search for the type of bodykit you are after i.e BBS kit click search ''BBS body kit'', alternatively ask specifically what bodykit you want a picture of.
snoops
- Major Helmet
or you could do a google search as its mostly m tech kits that pople have on here
Cotty
- Hartge Crew
Some Hartge stuff knocking about.
salami
i think i want a tec2 or m3 but am unsure what it looks like on my 2 door
mrLEE30
tech 2 will not fit on your car as an 87 is most probably a pre-face lift car, do your rear lights look like snoop and cotties touring above or are the reverse lights different. if they are different then your car is a pre face lift car. to fit a tech2 to a pre face lift requires modifications to quite a lot, you should do a search for a tech 1 kit and see if you like that.
i wrote an article on retro fitting most parts of the tech2 kit here have a look...http://www.e30zone.net/modules.php?name ... chmtec.htm
that should give you an idea of what a tech2 looks like, now look at the photo gallery for any tech2sports they will also have the kit, tech1 sports (or MK1 sport) will have the tech 1 kit which will be best for your car assuming its a pre facelift
M3 kits are available and get a mixed reaction from zoners, the wheel arches on an M3 are different (in fact so is the roof and screen angle, rear window angle and boot, the only common panel is the bonnet) so a badly fitted M3 kit is not a good idea, plus M3's only came in LHD so a kit would not fool anyone in the know if that would be your idea!!
salami
Thats spot on i will check all in the morning.
Im not after trying to make it look like anything its not but just wanted a lower allround look that i would get from a kit.
thanks for the info
thanks for the info
salami
definatley tec 1
mrLEE30
then go for it!!! tech 1 old school look is now very sought after, here is my tech 1 sport and my cab before i put the tech 2 kit on. the tech 1 on a 2 door looks the mutz nutz
