Sound deadening
215m3
Thu Feb 01, 2007 9:13 pm
I have ordered my new speakers for the fronts. 5.25 so a direct replacement.
I have heard that it's best to fill the space behind the speaker with sound deadening material. Is this the best thing to do?
Toby
1987 E30 M3 S14 Turbo
1971 V12 E type Roadster
miniblob
Fri Feb 02, 2007 9:36 am
Yeah, you want some dynamat style sound proofing (self adhesive sheet) and stick it on the panels where you can!!
Saying that, i haven't got round to doing mine yet so i'm not sure how much of it you can get to down there, so not sure if some spray stuff might be better!!
Would also help sound quality if you fitted/mounted them in a stronger, more rigid mdf ring!!
I'm sure others will come along with better info!!
327 Touring with bass!!!
ant_318is
Fri Feb 02, 2007 4:34 pm
You can get a roll of dynamat from motorworld for about £15.99 but not sure hom much u get. Definately recommended
Pyros
Fri Feb 02, 2007 5:49 pm
there is a cheper way, go to wickes and its like lead flashing stuff it comes in a roll you need to get the hi contact glue as well its just as good as dynamat but a lot cheaper and you get more for your money, i had to sound deaden one of fuels dodge challengers with the stuff when i worked for them it works a treat i have to get some so i will get the name of it over the weekend
215m3
Fri Feb 02, 2007 11:10 pm
cheers fellas
I have got a little amount of dynamat type stuf yo stick behind the speaker
Toby
