Early vs. late M20 differences?
Phatz
Post Thu Feb 01, 2007 9:55 pm
Guys!
My old man and I are faced with the possible prospect of having to replace an 89 325i Touring engine with a 1986 2.5 engine.
It is my understanding that there will be some differences between the two engines and I was wondering what problems we may come across during the swap if any (wiring looms etc...?)
Any advice from an M20 boffin or anyone that knows will be much appreciated as our bombined experience is limited. The car is an Auto!
kam-325i
Post Thu Feb 01, 2007 10:09 pm
The only difference between a late & early M20B25 is the compression ratio.......it will be a straight swap......
Phatz
Post Thu Feb 01, 2007 10:11 pm
That's the best news I've had all day! :P
Thanks mate!
Turbo-Brown
Boost Junkie
Post Thu Feb 01, 2007 10:16 pm
You might have to swap the front pulley across too as the really early engines had the crank trigger on the flywheel whereas the later ones used a toothed wheel at the front of the engine.
10 min job though :D
kam-325i
Post Thu Feb 01, 2007 10:18 pm
Turbo-Brown wrote:You might have to swap the front pulley across too as the really early engines had the crank trigger on the flywheel whereas the later ones used a toothed wheel at the front of the engine.
Now that is an early early M20B25 !!! dont think ive seen one yet....
Turbo-Brown
Boost Junkie
Post Fri Feb 02, 2007 7:43 am
:D No idea when they changed over, but certainly my 1985 engine had the flywheel trigger.
Ant
Retired Team Member
Retired Team Member
Post Fri Feb 02, 2007 9:10 am
Trigger wheel and sensor, water pump and engine loom need swopping over, you'll also need to swop the oil level sensor accross.
you must use the late AFM with the later loom, the early unit will not work correctly.
Nice swop, brings a good comp hike with it too.
mark_i
Post Thu Mar 01, 2007 7:18 am
Approx. what date did the change happen?
Is the toothed trigger wheel the definite feature to look for?
Phatz
Post Thu Mar 01, 2007 7:24 am
It's actually in the process now! The trigger wheel does need swapping over and we are going to change the water pump, oil sensor and AFM too!
