Hi, I wanted to find out if the alpina or m3 brain can be used on a 325sport and if so what modifications would need to be done. Any help will be much appreciated.
Win
Alpina & M3 Brain
march109
what would be the point??
win
Just a question, as i wanted more power and a friend of mine suggested changing the brain.
march109
yeah get a chip meant for a 325i though. Can be found in the zone shop.
or if your budget is a bit more go for MS, or another such remappable ecu.
there would be no point using an m3 or alpina ecu, as it wouldn't run the 325i correctly, the ecu takes signals from various sources around the car to decide how to best manage the engine according to the fuel/air map its loaded with. So if you used a ecu not specifically mapped for the right engine it would either run worse than before or not at all.
win
ok mate cheers for that i'll have a look in the zone shop.
By the way whats MS and what sort of price would it be?
march109
MS is megasquirt, its a bit intensive, and costs in the region of £700 including fitting.
www.megasquirt.info for info.
Or there are other solutions, other types of chip that are cheaper but can only be reprogrammed by certain rolling road centres, so you'd probably end up paying more in labour rates anyway.
the cheapest route for mildly a modified engine is probably the zone chip around £100, comes preloaded with a better than stock map. If you haven't allready look at big bore throttle bodies, 6 branch manifold/sports exhaust, at the extreme end of the scale performance cam shafts,
And better than all these for BHP per £, you can get free/cheap ponies by making sure the engine is well serviced with quality parts.
win
OK thanks for that
