Looks like i'll be dropping an m20 in the bm this w/end.. Its a facelift and the engine is from an early car i assume there is no issues with water pumps etc as im using the early management also..
the engine has been sat for a bit, im gonna change the engine and gearbox oil/filter/plugs... is there anything else that might need changin? will the water pump be ok etc assuming it was when the engine was in its previous home lol?
M20 swap
- Homo Hair
- Homo Hair
also how hard is it to split the engine and box and remove the flywheel?
how much does an m20 flywheel weigh?
A1BMW325iSport
yeah do the oil + filters etc, water pump should be ok.
splitting the engine and box is fairly easy, but its easier to drop the complete lump in,
flywheel isn`t that heavy tbh
- Homo Hair
anyone got an idiots guide to removing and refitting an engine.. gotta remove the prop and diff also.. only ever removed FWD lumps before
Jimbob
good luck. hopefully you're well prepared for this, my 4cyl facelift to 6cyl pre-facelift engine had many little niggles.
If you need anything mate I'll be able to go through all my invoices from the $tealers and supply any necessary part numbers.
Karan
u were there when we did daves u plonker!!!Jhonno wrote:anyone got an idiots guide to removing and refitting an engine.. gotta remove the prop and diff also.. only ever removed FWD lumps before
- Homo Hair
yeah but i missed the important parts whilst i was sleeping
the niggly bits are fine cause i saw/help/hindered with them
