How to remove rear pop outs
billgatese30
Post Tue Jan 30, 2007 9:15 pm
as title folks
how do you remove the rear quater windows on a 2dr (popout type, not fixed)
speedy replys appreciated
Chris
Chris-W
Post Tue Jan 30, 2007 9:21 pm
There are two 8mm nuts behind the b pillar - bottom one behind a dedicated plastic cover, top behind the coat hook.
You'll need a narrow 1/4" socket!
Then hinge, of course.
billgatese30
Post Tue Jan 30, 2007 9:33 pm
cool, cheers chris
when you say coat hook, do you just unscrew that to reveal another screw?
Chris-W
Post Tue Jan 30, 2007 9:39 pm
Unscrew the coat hook, and then lever it out. It's still quite tight without the screw.
billgatese30
Post Tue Jan 30, 2007 9:45 pm
cheers Chris :cool:
appletree
Post Tue Jan 30, 2007 10:37 pm
theres a tech artical for fitting opening rear quarters which covers the removal of the normal ones, might be worth looking at for the pics :D
http://www.e30zone.net/modules.php?name ... window.htm
