question about fitting clutch? M42
DawsiRn
Post Mon Jan 29, 2007 8:12 pm
Hi i was about to go ahead and replace the clutch on my 318is but i havn't got the right socket bit to take the pressure plate off! anyone got any ideas to which size bit i need?? it's one of these star shaped socket bits just dunno what size is needed..
cheers.
m-dtech
Unapproved Trader caution
Post Tue Jan 30, 2007 12:47 am
clutch should be an allen key type bolt.
IIRC its 6mm
best type to get is a socket one and use a ratchet making sure that it does not slip off.
the bolts are really soft and you will mangle the inside if you slip off the bolt, leaving you no option other than chisseling them off.
