M50 Question
Gabi_323i
i have a non vanos 2.5 with a cracked head, and a 2.0, can i use the 2.0 head with 2.5 camshafts on the 2.5 block?
No, the bore sizes are different.
Where has the head cracked out of interest?
Gabi_323i
so what? on the 84 piston diameter 2.7 we use the 2.3 80mm head, wouldnt be the same thing? i don't know but water gets in #3 cylinderDanThe wrote:No, the bore sizes are different.
I just know they are not the same as the 2.5 so I wouldnt use it.
Have you had it pressure tested then?
Gabi_323i
i don't have where to do that
m-dtech
- Unapproved Trader caution
here ; http://www.bmwworld.com/engines/m50.htm
all the technical specs of the m50 engine
has no one heard of google ??!
benjy
Bark?!?!?! Do tou know how to use Google?!?!?!
^^ do i know how to type?!?!
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
m-dtech
pmsl, i just dont know how to copy and paste !!
now edited
now edited
