faulty fuel gauge reading....
kingwajuk
hi folks,
I've been away from a few months as i sold my 318 cab, but now im back! I've just brought a 318i with full mtec2 kit and resprayed in dakar yellow of a zoner.
The guy i brought the car off told me that some1 tryed to ram a hoze down the filler neck to nick some fuel and pushed the float aside thats why im getting a faulty reading.
So how do you get into the tank to put the float back on? ive removed the rear seat and ive found 2 inspection panels. One has 2 sets of wires going into it but doest realy look like i could get my hand down there to play around inside.
The other black pannel just has a fuel pipe running through it,no visable access to the tank?
I'd be realy greatful if some1 could help me out on this cause i dont realy know much about the e30's.
There are four small nuts on top of the plate with the wires you've found.
Pull the plug off, unscrew the four nuts and washers, and pull the float unit (aluminium oval cylinder) straight up and out.
Fuel will dribble out of the unit as it comes out, so let it drain into the tank before completely removing it.
All E30 sender units are the same, so a scrapyard will produce a new one for you.
kingwajuk
just tryed that! just borrowed my mates one and its still the same.
isnt there a float or something in the tank?
I didn't really think it would cure the problem TBH, but that's the fuel level sender unit - the float is inside the aluminium tube.
Some E30s have a second sender unit under the round black cover as well, but not yours.
First question, before we do some serious fault finding, is: What exactly does the fuel gauge do, or not do?
kingwajuk
when the gauge is reading half way, the red warning light is comming on.
When i took out the sender unit out there didnt seem to be much fuel in the tank so im sure its pretty close to reserve.
Reading half way when empty suggests the car may have been fitted with an instrument cluster containing a fuel gauge from a car with the twin sender set up in the tank.
No great problem in itself, as you can almost certainly find someone on here with the opposite problem and do a swap, but it probably means the mileage on your car isn't what you think it is, as it's probably not the original speedo.
Orange warning light should come on when there's about six litres left in the tank.
kingwajuk
The dials have been played around with as the dials have a carbon fibre surround. Il head to the scrappy 2moro and grab a new set of dials.
Is there anything else that could be causing the problem?
Make sure the scrapyard dials come from a car with just one sender. (check under the round inspection cover under the rear seat).
You actually only need the fuel gauge, which is just held in by a nut on the back.
If you have a choice of dials at the scrapyard, and have the time to check, open them up and check the circuit board which is fitted into the front half. Near the middle are two batteries. Some boards have AA sized batteries, and some have batteries which are much shorter. Go for the shorter battery type.
There is a white plug on the lower front face of the dials, called a coding plug. This plug should be fitted to your new dials, especially if your new dials come from a six cylinder car.
kingwajuk
I'm guna take the dial out from the same car which i took the sender out from. Its a 318i touring so i assume it should already have the right dials. Could I get away with just changing the fuel gauge? The dial in the scrappy has 160,000 miles on it and dont realy wana use the whole set of dials.
Fuel gauge alone can be swapped over.
kingwajuk
Just swapped over the fuel gauge and its still the same!
Any other ideas??
kingwajuk
anyone got any ideas?? im pretty much outa ideas now!
Fuel gauge is a fairly simple electrical circuit - Just the gauge with ignition 12V+ going to one pin, another pin earthed, and a third pin connected to earth via one (single sender tank) or two (twin sender tank) variable resistors.
Either you haven't got a gauge from a single sender car, or some one's been messing with the wiring!
Have a look under the back seat for wiring that looks like it should be going to a second sender.
Possible that the tank has been changed from twin to single sensor, and some one's added a resistor in place of the second sensor in an attempt to correct the reading.
kingwajuk
the new gauge is deffo from from a single sender like mine.The wires that connect to the sender havent been messed around with, however the 2nd set of wires have been crimped?? could this be the cause?
There shouldn't be another a branch off the loom to a second sender if the car didn't have one originally.
Time to do some resistance checks on the loom, I think.
The brown wire at the level sensor should be zero ohms to battery negative.
The brown/green wire at the sensor should be zero ohms to the brown/green wire at pin 4 of the white connector at the instrument cluster. (with the plug still connected to the cluster, you can access this wire at pin 5 of the yellow socket, which will be unused unless you have an OBC.
ad318i
u sure its a single sender... cos even though the car was a 318i the tourings have bigger fuel tanks.... leading to them having the twin senders
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
