standard 86 325i vs 89 325i vs sport etc
jackdaniels318is
i have heard the compression ratio is slightly different on the phase 1, the one i am looking at allso has no power steering will this help power rather than when you have pas? allso sport had m-tech suspension but did a 325i have the bigger front struts std? (51mm?) not sure what size they are. reason is am looking at getting one as a very tight buget track toy. thanks for any replys of help.
maxfield
toureres cabrios 318is and 325s came with 51mm struts
having no pas will help with feedback through the steering but got to be built like arnold swarznegger (sp) to park it
jackdaniels318is
so if i got the m-tech inserts of a sport/318is they would be fine to go strait in? to make a sport out of a 325i se mechanically, do i just need the shocks and lsd? does the sport box make much of a difference?
Theo
Shocks, springs, diff, gearbox, and rear anti roll bar were all different on the sport compared to a bog standard 325i.
gooner1
- Out humping Reindeer
Think there is a sport box and diff for sale in the For sale at the moment mate.
snoops
- Major Helmet
sports camewith a close ratio gearbox, pre facelift 325s had higher compressioned engines wheras the later 1s had a lower compression
jackdaniels318is
so really witch is faster a tech 2 with pas or a tech 1 with pas? as i would think any with out pas would be quicker would i be right?
dazleeds
- old skool raver
tech1 is faster than tech2 periodjackdaniels318is wrote:so really witch is faster a tech 2 with pas or a tech 1 with pas? as i would think any with out pas would be quicker would i be right?
on the road the lack of pas will add nothing powerwise
www.oldskoolfantasy.co.uk
maxfield
I always thought PAS took power away from the engine for it to run ??
Maybe rong tho
Maybe rong tho
jackdaniels318is
why is tech one faster what evidence is there?
orangecurry
no, you are correct Grasshopper; anything running off of the engine will steal a few BHP, and the PAS itself weighs something - it all adds up.maxfield wrote:I always thought PAS took power away from the engine for it to run ??
Maybe rong tho
tut tut Daz.
jackdaniels318is
so tech 1 is faster to 60?
drifty325i
Hell year way quicker
The V8 in action http://www.youtube.com/watch?v=vp5Eaf8xOgM
drifty325i
Lighter and more powerfull
