Shock Removal from Leg
cliffybabe
- Powered by Nelly
Guys
Im trying to remove the shock cartridge from the leg but i cant get a grip on the collar any idea's or tricks to releasing the shock cartridge??
Neil
Neil
Theo
You really need a stilson grip/pipe wrench to do the job.
Yep, stilsons are the tool.
If your replacing with new collars you could use a hammer and chisel, but you dont want to go tightening them up that way
cliffybabe
- Powered by Nelly
Cheers guys, im going back out to the garage now for another try,
Dan i have got new collars aswell mate, so tighten thrm up with hammer and chisel??
oze30
Id tighten them up with stiltsons!cliffybabe wrote:Cheers guys, im going back out to the garage now for another try,
I meant you can remove them with a hammer and chisel, I wouldnt tighten them back up like it though because they will be in a right state!
- **BANNED**
Hope that these are chrome fittings....
Morat
He wouldn't put a chisel near chrome.... maybe a wetwipe ;)
fuzzy
i had to seek help from my friendly local kwik fit to give them a blast from the gas torch as mine were rusted solid
and wouldnt budge even with the stilsons and a vice
Simon
Use a grinder and cut a bigger groove into the collar, apply a lot of heat, and then a chisel and a big hammer, that should sort them!
Dan318-is
Alternatively, bolt the hub back into one of your wheels with the four wheelbolts; lie the wheel face down and it will be much easier to grip the leg; then use stilsons to undo the nut and plenty of wd40; i told you at lakeside it would be a cunt!
reference to the chibster for the tip
Demlotcrew
Yeah thanks for the reference, to my idea!Dan318-is wrote:Alternatively, bolt the hub back into one of your wheels with the four wheelbolts; lie the wheel face down and it will be much easier to grip the leg; then use stilsons to undo the nut and plenty of wd40; i told you at lakeside it would be a ****!
Andrew
Andrew he watched me do it!
Dan318-is
didn't no it was a world renowned secret to be honset?Demlotcrew wrote:Yeah thanks for the reference, to my idea!Dan318-is wrote:Alternatively, bolt the hub back into one of your wheels with the four wheelbolts; lie the wheel face down and it will be much easier to grip the leg; then use stilsons to undo the nut and plenty of wd40; i told you at lakeside it would be a ****!
Andrew
trueSimon13 wrote:Andrew he watched me do it!
maxfield
I'm sure people thought of that way way before you did
cliffybabe
- Powered by Nelly
all done guys, shocks are in and new cab springs are on the front, Im quit epleased with myself as i have done it all on my own.
Whilst i was at it i also fitted new top mounts as mine had some play.
Thanks for all the help with the removal side of things, I ended up putting them in a vice and using some huge stilsons which i borrowed of a gas fitter
Tomorrow ill put the rear springs in and stick up some pic's
Thanks again
Neil
Thanks again
Neil
Dan318-is
good work you chrome fiend
Demlotcrew
When you can word together a sentence, then I might listen to what you have to say.maxfield wrote:I'm sure people thought of that way way before you did
Andrew
Dan318-is
Andrew, credited above
cliffybabe
- Powered by Nelly
Demlotcrew wrote:When you can word together a sentence, then I might listen to what you have to say.maxfield wrote:I'm sure people thought of that way way before you did
Andrew
stuartgallafant
cliffybabe
- Powered by Nelly
See Stu i told u im a good watcher, Na all jokes aside well pleased and i hve lowered the rear aswel
And Si i think u were right the springs were saloon springs first time round
- **BANNED**
Chrome springs?
cliffybabe
- Powered by Nelly
na red but the bolts from taylor are now on and there shinydaimlerman wrote:Chrome springs?
- **BANNED**
Is red the new chrome?Bet they look smart,well done!!
ric325i
yeap the red wont last long. they get dirty!
i know your pain in changing suspension! had same issues and discovered a big saw (on the collar) then a hammer and screw driver to take off!
very destructive......i liked it!
but the issues cam when re-attaching the collar! i didnt tighten the up properly...
the collar came loose and popped of and the leg wobbled around very strangely!
so it was back to the spring compressors and start again
buster
another tip is to refit the strut to the car minus the spring.Bolt one or all 3 strut top bolts up and pop it back on to the ball joint and steering joint and then its held in place,then use stilsons on the nut to undo it.
