I recently pulled out and air conditioning system from an '86 325i, but it seems to be a hybrid of BMW and Diavia parts and has a couple of quirks.
The system uses a proper BMW air con heater box (i think) part number 64111386521. It also uses the BMW switch with the two buttons.
It has motors to open/close recirculating flaps on heater. These motors have no limit switches or stops and are always powered on either open or close and one of the flaps has cracked as a result.
It has a few unused plugs around the heater box, is this the same on other E30's ?
The recirculate and aircon switches each switch the heater blower onto 1 and not 0 as per the owners manual.
The system has been out of use and empty for some time. Will it need/can I get seals for the joints and compressor and a new drier? Am I right in thinking you can get a kit to convert from R12 to R134a?
Any help appreciated,
Theo
Air Conditioning Queries
So i am told, the system should run on R134 fine as long as all the R12 gas is removed first. I meant to do it on the auto as the system was still sealed with the old gas in it, which is a first. There wasn't enough to get it to blow ice cold but it did blow cold.
it's a dealer retro fit miss fit kit though theo? your not putting it in one of your cars? My touring is saddled with this sh!te at the moment also
Theo
I was going to fit it to my car, want to swap the dashboard anyway, so thats an excuse to put the aircon in. I would like to take a peak at the aircon on your touring to see if they use the same bodged kit of bmw and diavia bits.
Demlotcrew
Fit it theo, mines just needs some gas now
With thanks to Ian and Jake and Mark (for info and parts)
Andrew
Andrew
