Please help my 325i is not working!
Skidmarkmike
Post Fri Jan 26, 2007 12:38 pm
Hi all,
In the past all posters have been a great help as I know very little about cars. Have 325i auto E reg. 180, 000 miles.
Latest issue is: After running fine for the last two months, when the snow came went to start the car early in the morning and it turned over for a few seconds then engine died. Tried again and same, third time lucky it turned over and eventually started after about 10 seconds engine died. Got jump leads from car to the battery and still no success.
Mechanic came out at a cost of £50 and said battery is ok but old, cleaned the spark plugs and had a boost pack and a connection to his truck and engine started, it went for a few minutes and then as soon as the mechanic had gone it died again. He said get new spark plugs.
Fitted a new battery another £50 tried it sounds better but still not starting and am now waiting to get six new spark plugs £15.
Will fit those tonight and give it a try with new battery. How hard is it to do, (to fit spark plugs) have also purchased a spark plug spanner.
Does this seem like a sensible course of action or should i try something else?
Please help.
Regards skidmarkmike.
PS If i sell the car and be rid of it to someone who knows what their doing what should I expect to be offered £Â£Ã‚£ ?
oakey
Post Fri Jan 26, 2007 1:55 pm
. try the new plugs and see how it goes. i know it sounds really silly and i dont wana sound rude but is there petrol in the car. i find that its often simple things like that that have been ovelooked
marty1979
Post Fri Jan 26, 2007 2:04 pm
Also, it could be that the fuel pump isn't operating correctly, either the pump itself or the relay, or even a fuse(number 11 in the fuse box) When you turn the key to the last click before the starter motor kicks in, do you hear the pump make a buzzing sound for about 2 seconds? If not then that could point to pump or relay probs. Also have a look at the crank sensor, sometimes the wires can rub on the flywheel and the connection between the sensor and the ecu will be lost and won't start. I'm sure someone with more ideas/knowledge will be along soon :)
Post Fri Jan 26, 2007 2:07 pm
Spark plugs are easy to replace; pull off the HT leads going onto the old plugs (they can need a bit of a tug), unscrew the old ones (your car should have a spark plug spanner in its bootlid toolkit!). Look at the tips of the old plugs - they should all be light brown in colour if the engine is healthy. Screw in the new spark plugs, taking great care to gently screw them at the correct angle into the soft aluminium threads - you only need to nip them up tight with the spanner, they don't need much force!
The car won't be worth much with that age, mileage and if it has starting trouble I'm afraid.
Skidmarkmike
Post Fri Jan 26, 2007 8:21 pm
Hi guys
Thanks for the advice.
I fitted the new spark plugs and it started up with a jump. Drove round the block and it cut out 4/5 times, started and carried on round the block every time, but then just died at 30mph and faded to a halt. Had a look under the bonnet at the side of the road and saw the suckers (HT leads?) to the spark plugs had come out. fitted them again this time with taking the little metal screw bit of the top of the new plugs and obtaining a better connection with the suckers and the plugs. Turning over but just doesnt want to start.
Battery is fine, new spark plugs now fitted correctly. still not starting.
Please help. I think it must be the ignition??? There is petrol in it definetly.
PS I have abandoned the car at a mates in Surbiton, Surrey, so if ayone is local and could help and is cheaper than a £50 a time mechanic or knows a BMW 325i specialist nearby then please get in touch.
Am depserate.
R :cry: egards Mike
dazleeds
old skool raver
old skool raver
Post Fri Jan 26, 2007 8:27 pm
sounds fuel related to me as said
when it started and ran was it running ok? as usual?
i know u can bridge some pins to get pump going but not sure which sorry
you need brianmoore i think for this one
www.oldskoolfantasy.co.uk
marty1979
Check the crank sensor wiring, someone on here had a similar fault and it turned out that the wires were rubbing on the flywheel and eventually wore through. Have a look tomorrow morning.
Post Fri Jan 26, 2007 8:28 pm
Could be worth replacing the fuel pump relay, fitted under a black plastic cover between the radiator header tank and power steering reservoir. It is (usually) orange in colour.
Post Fri Jan 26, 2007 8:38 pm
This thread explains which pins to bridge in an emergency like yours:
http://www.e30zone.net/modules.php?name ... onstarting
Post Fri Jan 26, 2007 9:54 pm
What colour were the tips of the old spark plugs?
Very much doubt that plugs were the cause of your trouble, but a new set won't hurt.
For an engine to run it needs compression (unlikely to be the problem), fuel and sparks, both delivered with the right timing.
First checks to do are for sparks and fuel - take one of your old spark plugs, pull a lead off one of the spark plugs in the engine, push it onto the spare one and lay it on top of the rocker cover.
Crank the engine over on the starter motor. Does the plug spark, once every two turns of the engine?
Pull out the orange fuel pump relay under the plastic cover on the inner wing near the air filter. Remember which socket it came from! Take a short piece of wire and short together pins 30 and 87 of the relay socket (pin numbers are marked on the relay).
Does this produce a hum/buzz from the fuel tank at the back of the car, indicating the fuel pump is running?
If not, remove the link, remove the fuel pipe from the fuel rail (NOT the one that goes to the top hat shaped fuel pressure regulator), place the end of the pipe in a container, and put the link back in place. This should make fuel surge out of the fuel pipe. (beware sparks and petrol vapour).
